Old 09-25-2020, 05:44 PM   #1
Light sewer smell behind toilet
Doing my recent trip noticed a little sewer smell behind toilet in bathroom after a couple days at camp site. Using FHU so emptied tank and fully flushed it out, but smell still there. Don't see any leaks outside or inside. Connectors to toilet appear tight. This is a 2020 2104S Rockwood MiniLite.
Any ideas?
Dotsos is offline   Reply With Quote
Old 09-25-2020, 07:14 PM   #2
Just as confused as you
Scrapper's Avatar
The plastic Dometic Model 300 toilets are notorious for leaking between the bowl and base. The bowl leaks into the base. Call Dometic and upgrade to a 310 or 320 china toilet. The problem has been going on for years and it's a shame Dometic is still making a toilet that always leaks.
Richard & Jill
Camping since 1989, seasonal since 2000
I deserve hazard pay when camping with my relatives.
Old 09-25-2020, 07:25 PM   #3
Originally Posted by Dotsos View Post
Doing my recent trip noticed a little sewer smell behind toilet ...
Wait 'til it ripens. It won't be "a little."
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is online now   Reply With Quote
Old 09-25-2020, 07:37 PM   #4
Light sewer smell behind toilet.
Scrapper, do you mean it actually leaks onto the bathroom floor? If so, we don't have that issue. Or is it "silent but deadly"
Old 09-25-2020, 07:51 PM   #5
Originally Posted by Scrapper View Post
... Call Dometic and upgrade to a 310 or 320 china toilet. ...
Don't upgrade to a 320 unless you know it fits. I have a 310 coming as a replacement for my 300 but haven't received or installed it yet. From diagrams I've seen, the clearance of a 310 from the wall behind it matches the 300. That is not true of a 320, which requires more space, and for which the outlet offset from the wall differs similarly.
Also, I started the process by waiting on hold for an hour with Dometic, only to be told I had to go to a "service center" for replacement. I did that by way of a phone call to RV Wholesalers, where I bought my trailer. (I live outside Ohio.) They've arranged for one to be shipped to my home. I'll install it myself, which I prefer for timeliness and hassle reasons.
Old 09-25-2020, 08:03 PM   #6
He means that some of the urine is retained inside the toilet itself. Is that the toilet that you have? The problem is specific to the toilet model.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 09-25-2020, 08:18 PM   #7
Great info. Thanks
Old 09-25-2020, 10:33 PM   #8
Scrapper's Avatar
No, the leak is between the bowl and the base. Because of the way the two pieces join together waste water stays inside the base. As far as I have read on this forum is there is a dish-like lip surrounding the neck for the bowl that fills up then the excess runs down into the opening to the black tank. There is a post where someone took a photo showing where the problem lies and where the waste water gathers.
Look under the toilet on the back half for a sticker with the model number, if yours is the 300 model (plastic bowl, plastic base) then the problem is well documented on the forum. If you have a 310 (china, round bowl) or a 320 (china, oval bowl) then most likely someone keeps missing the target.
DW keeps asking why we need a nightlight in the bathroom at home and the TT.
I tell her, "I'm not afraid of the dark".
Richard & Jill
Old 09-25-2020, 11:33 PM   #9
Thanks Scrapper for the follow-up info. This is very helpful and pretty sure it is the 300, but will confirm.
Looks like a trip to the RV repair shop. Love the night lights, too. 😀
Also, Chris C. appreciate your info on which model to replace it with.
Old 09-26-2020, 01:23 PM   #10
... pretty sure it is the 300, but will confirm. ...
Because of the position of the sticker, the only way to see it is with mirror or using a smartphone in selfie mode. I had to adjust the selfie setting so it didn't appear as a mirror image.
I was told I'll need to peel off the label and return it to the dealer as part of the warranty repair. I won't have to do that until I replace the toilet.
Old 09-26-2020, 01:32 PM   #11
Good to know. Thanks
Old 09-26-2020, 02:25 PM   #12
dmctlc's Avatar
Just curious is the dealer you bought it from close by? Call the service manager tell him what you know after you verify the model and see if they'll do all the work for you including covering the cost of replacing that piece of junk with a better model. Just a thought!
Dana & Terri - (Retired)
Stephanie (daughter)/Rick/Callie (12 y/o)
Phillip (son)/Alyssa/Charlotte (4 y/o)
Our Cocker Spaniel "Shadow" (4 y/o)
dmctlc is online now   Reply With Quote
Old 09-26-2020, 02:55 PM   #13
Replaced our 300 with a 310, smell went away. In the meantime try mixing some soap and vinegar in a spray bottle and spray around base. Helps greatly in keeping the smell under control. Seemed to be the only thing that helps.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 09-26-2020, 02:59 PM   #14
Thanks, did that call to dealer this morning. Have appointment to install upgraded one under warranty. Just don't understand, since it's a long term known problem, why Dometic continues to install this cheaper, bad product, since they then are frequently replacing them under warranty??
Old 09-26-2020, 03:25 PM   #15
Dometic doesn't install them, Forest River does.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 09-26-2020, 04:03 PM   #16
dmctlc's Avatar
Glad you called the dealer and they're going to dot he swap.
Thanks for the update.
Old 09-26-2020, 04:07 PM   #17
Try this
I used to get that. What I did was open the toilet with the foot flush and take a garden hose and clean it real good in side. Works like a champ. No more smell. I think I will alway do that occasionally in the future
TGO Bill is offline   Reply With Quote
Old 09-26-2020, 04:17 PM   #18
Forgot to add
I forgot to add to my post that you could/should use a spray cleaner to help clean it up in there
Old 09-26-2020, 04:19 PM   #19
Scrapper's Avatar
The real question should be "Why does Dometic still make this flawed, crappy toilet after all the replacements they had to supply?"
Richard & Jill
Old 09-26-2020, 04:25 PM   #20
Sounds like a lot of the time, they are actually *selling* replacements (upgrades), and at $75, probably making a little bit of profit on them, too! So they sell the original 300 to the manufacturer, and then sell the upgraded 310 to the consumer - sounds like a win/win.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is online now   Reply With Quote
light
