Old 10-12-2020, 10:52 PM   #1
Old man RVer
Looking for a reliable water flow meter
I want to partially fill the fresh water tank and do it with more accuracy than the onboard gauge. So I’m looking for a flow meter to go in the fill hose. I’ve seen the plastic ones sold on Amazon and most seem to have a short life span. I don’t want to pay $100 for a meter I’ll only use a couple times a year but would like one that won’t break after a couple uses.
Any suggestions?
2WheelJon is offline   Reply With Quote
Old 10-13-2020, 04:14 AM   #2
I've been using the plastic one for 5 years with no issues. The key is to use a 90 or 45 degree adapter to keep the stress on it vertical.
hinkle_e is offline   Reply With Quote
Old 10-13-2020, 05:33 AM   #3
I use this one (Rainwave RW-9FM LCD) but it's out of stock. I've had it for over a year now with no issues. There is a similar model that may work as well. Yes it's plastic. I typically use it at the spigot and not at the camper connection so it keeps the weight off the plastic. This Orbit seems to be the exact same one I use https://www.amazon.com/Orbit-56854-H...49413728&psc=1
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47
Electra glide is offline   Reply With Quote
Old 10-13-2020, 09:07 AM   #4
Old man RVer
Thanks, very good advice.
Old 10-13-2020, 09:40 AM   #5
Hatchdog's Avatar
I have one similar to the Orbit shown above and in fact it might be the exact one. I checked mine for accuracy with a five gallon bucket and found it to be spot on. Used it several times and then it quit working just like many of the reviews I read on it. At the beginning of this season it continued to not work and then all of a sudden it worked again I’m winterized now but we will see what next season brings.
2020 Rockwood Ultra-lite 2608BS TT
2011 F250 Lariat 6.2 gas 6 sp auto 3.73 rear 4X4 6.75’ bed crew cab
Recurve R6 hitch
Hatchdog is offline   Reply With Quote
Old 10-13-2020, 03:30 PM   #6
jbrosecity's Avatar
https://smile.amazon.com/gp/product/B07FYQZ54J/
SAVE A DROP WATER METER by P3 INTERNATIONAL - MEASURES GALLON USAGE FROM GARDEN HOSE
works perfect - use it a lot
2019 Forest River Forester 3041DSF
Ford E-450 Chassis
www.Wind-seeker.com
2018 Vanleigh Vilano 375FL
www.Wind-seeker.com/vilano
jbrosecity is offline   Reply With Quote
Old 10-13-2020, 04:01 PM   #7
X2... here's mine. been working perfectly for 5 years.
Days Camped: '18=51 '19=58 '20=110 '21=21
Old 10-14-2020, 12:30 AM   #8
jbrosecity's Avatar
Yep I always use it when saniflushing the black tank. I run a timer with an alarm set for 8 mins and wear it around my neck and I keep this monitor running to watch how many gallons I am pumping into the black tank with the dump valve closed. I don't want to tell you how and why I evolved this fail safe system... an ugly story or two there that caused the DW to swear she was DONE with RVing. But watching the gallons and the time, I have never screwed that up again. Praise be!
I can hear some saying they never run saniflush with the dump valve closed... safer yes! but not nearly as effective as partially filling the black tank and then opening the valve. Just don't wanna overfill, trust me!
Ford E-450 Chassis
www.Wind-seeker.com
Old 10-14-2020, 04:52 AM   #9
DouglasReid's Avatar
Any suggestions?
Get a 5 gallon bucket and see how much time it takes ur hose to fill it. Use that time x however much water you want in the tank to determine how long to leave it running.
Easy peasy
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 10-14-2020, 08:26 AM   #10
Easy peasy
This works well of you use the same spigot each time. If not the available flow from the spigot changes throwing off your calculation.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 10-14-2020, 08:42 AM   #11
And not only the same spigot but opening the spigot the exact same amount every time. (I don't fill my tank full blast so I regulate it by the amount the spigot/shut-off valve is turned) Add that to any decrease in flow in the filter you use (as it is used over the summer) to filter the water going into your tank, coupled with different hose diameters and you'll have some varying results as well. Also, I've seen campgrounds where the pressure varied greatly throughout the day so depending on what time you may use the water, flow is anyone's guess.
This is why I put my meter right at the fill port... takes all that other stuff out of the equation.
Old 10-16-2020, 10:20 AM   #12
2thdr's Avatar
Do you happen to have a shopping list for all those parts? Very nicely put together!
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2014 CRF250L
2017 FZ-09
2thdr is offline   Reply With Quote
Old 10-16-2020, 10:40 AM   #13
Not really.
The clear fill tube and barbed garden fitting were parts I had laying around.
The barbed garden fitting is a repair fitting for a broken hose and available at any hardware/home improvement store. (I simply didn't use the included S/Steel hose clamp as the hose fit tight enough)
The meter was linked to earlier. (I paid less than $22.00 for mine)
The garden hose shut off is a Gilmore brand full flow shut-off.
Gilmore Poly Full Flow Shut-Off
The quick disconnects came from Wally World.
Expert Gardener Black Heavy-Duty Metal Hose Quick Connector Set
Old 10-16-2020, 10:41 AM   #14
2thdr's Avatar
Not really.
2015 DL1000A ADV
2014 CRF250L
2017 FZ-09
Old 10-16-2020, 10:48 AM   #15
You are welcome.
Just a note on the garden hose shut-off...
I like to use "Full Flow" shut-offs everywhere.
Typical inexpensive shut-offs have a tiny 1/4" hole in them restricting the flow.
These do not, they are full flow. I'll see folks with 5/8" or 3/4" hose bragging they are supplying their R/V with more water and then use an inline shut-off (or "Y") with a 1/4" hole! LOL!
Old 10-16-2020, 10:52 AM   #16
2thdr's Avatar
You are welcome.
Good to know...thanks again!
2015 DL1000A ADV
2014 CRF250L
2017 FZ-09
water, water flow
