Old 10-18-2021, 07:33 AM   #1
Low/no water pressure
I have little water pressure in kitchen running off pump. Checked for air and water leaks and none found. Hooked up to city water and got good pressure in kitchen and shower. I initially had none in bathroom sink or toilet. Then after an hour or two i got good pressure in bathroom sink and slow water in toilet. Looked at sink screens and found gunk. Drained hot water tank and cleaned out a lot of junk. Have sinnce tried pump again. I hear it humming and i get low pressure only in kitchen again. Tore pump apart diaghpram s all move and see no problem. I have not changed on board filter. Could that be cause or are there any other possibilities? I have a 2021 geo pro 19fd.
Adogbmw is offline   Reply With Quote
Old 10-18-2021, 07:55 AM   #2
Yes your onboard filter could be part of the problem . they should be replaced every yr . they get pretty nasty sitting in water even if not used that much . also filter on pump inlet could be clogged . also if your kitchen is in a slide you may have a kinked lines
MR.M is offline   Reply With Quote
Old 10-18-2021, 12:11 PM   #3
Pulled filter. No change. I'll keep looking
pressure, water
