Old 10-17-2020, 10:33 PM   #1
Low Point Drain in Concord 300DS
How do I empty the low point drain if the drain hose is flush with the floor?
2020RVRookie is offline   Reply With Quote
Old 10-18-2020, 08:21 AM   #2
SeaDog's Avatar
Are you sure where you have that hose connected is a low point drain and not the winterizing point for your system?
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-18-2020, 10:10 AM   #3
Itís confusing because the sign there says low point drain. Not sure if itís the clear tubing and white valve or what?
Old 10-18-2020, 10:20 AM   #4
SeaDog's Avatar
Little hard to tell but I would think from the pic the low point drains are the red and blue lines in the lower part of the pic have you checked outside in that area.
Retired Navy
Old 10-18-2020, 10:25 AM   #5
What do you think the clear tubing and white valve would be for?
Old 10-18-2020, 10:31 AM   #6
SeaDog's Avatar
I think its your winterizing port you can test it by taking a clear jug of water open the valve put the hose inside and start your potable water pump with a faucet open if the water level goes down you have your answer.
Retired Navy
Old 10-18-2020, 10:49 AM   #7
Ok. Thanks for your help!
Old 10-18-2020, 11:00 AM   #8
SeaDog's Avatar
don't leave us high and dry once you verify one way or the other let the forum know it helps out forum members
Retired Navy
drain
