Old 07-29-2020, 09:15 PM   #1
Question Low point drains
Are there valves on the low point drains or just the caps at the ends?
Greg58 is offline   Reply With Quote
Old 07-29-2020, 09:42 PM   #2
Mr. Dan's Avatar
The answer to your question varies by division, by model in the division, possibly by day of the month. My 2015 Wildcat has screw on caps on the low point drains and the fresh water tank drain. Post your division, year & model and someone with the same unit might help.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 07-29-2020, 09:59 PM   #3
Newbie- 21 FBRS
Swapped out
I had caps, but swapped them out for valves. Much easier to drain.
2019 Flagstaff Microlite 21 FBRS
TOW vehicle- 2020 Ram 1500 , 5.7 Hemi, 3.92 rear end, tow package with trailer blind spot.
Max Tow capacity-8379 with full payload
Max payload- 1721
Coevers is offline   Reply With Quote
Old 07-29-2020, 11:23 PM   #4
bikendan's Avatar
For what year, make and model of RV are you asking about? You have no information in your profile.
Those locations vary wildly between brands and models.
Old 07-30-2020, 01:28 AM   #5
If you have caps on the ends, then you probably don't have valves. For the red and blue ones, you're going to want to open up the faucets to drain the lines. The clear one is for the fresh water tank and you just have to take off the cap to drain it. Just don't lose the caps.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 07-30-2020, 07:25 AM   #6
Ours came with caps for the low point drains. Going to replace them with valves.
2020 Flagstaff Micro Lite 22FBS
Old 07-30-2020, 07:30 AM   #7
Georgia Rally Coordinator
aceinspp's Avatar
One of the first things I did was replace caps with valves. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-6
Old 07-31-2020, 06:58 PM   #8
Newbie- 21 FBRS
Here is what I used:
Polymer Ball Valve Inline 1/2"
Learn more: https://www.amazon.com/dp/B0080KI7RU..._M.kjFb3GZKMZZ
Max payload- 1721
drain
