Originally Posted by apuf
I have low water pressure in my 2000 Georgetown. Any ideas on what may be the problem?
Not much information. Pump pressure is low from on board pump or you're getting low pressure when connected to city water?
Check filters and also the screens in the faucet outlets. Mine were clogged and would not even let water trickle out. Took them off, cleaned them and all was fine! Other than that, not much else it could be. If still no pressure then you might have a bigger problem.
Good luck!
