Originally Posted by wanderingbob
Use as large hose as reasonable , maybe even PVC pipe . It is not the distance , it is the friction . Use LARGE wires if it is 12 volt . I use a 100 foot one inch hose and I use large jumper cables for power .
Distance is important but more important is "lift". Higher the liquid has to be lifted the more current the pump will draw.
"Flat ground" shouldn't be an issue at all.
