Old 02-01-2017, 02:07 PM   #1
Missing water filter
Hello everyone.
My wife and I are new owners of a 2010 forest river rockwood signature ultra-lite 8317ss.
Even though the dealership "winterized" it, before I put it into storage I wanted to kind of go through everything to start to learn our new trailer.
I found the water pump and location of where the water filter should be located, but there is literally just the white screw top where I assume the filter and housing would be located. I looked through the manual and search this site and couldn't find and part numbers or anything.
Hoping someone might be able to steer us in the right direction.
Thanks,
Mike
Mojosvt is offline   Reply With Quote
Old 02-01-2017, 02:18 PM   #2
Originally Posted by Mojosvt View Post
Hello everyone.
Thanks,
Mike
Are there plumbing lines attached to it?
Many folks have bypassed the filter (hooked the in-out lines together) and left the filter head screwed in place.
If there are lines attached to it, the housing and filter 'may' have been removed for a type of winterizing and stashed somewhere in a drawer/cabinet.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 02-01-2017, 02:25 PM   #3
Below are photos of the two most common filter housings/canisters FR uses.
You should be able to match and get numbers from the photos.
ID:	129025   Click image for larger version
Old 02-01-2017, 04:02 PM   #4
WFD
As 5picker says....did they bypass it, cause a great many of us have. A search on the topic here will give you hours of reading material where people have had trouble with those filters getting undone, hearing a thump in the middle of the night to find water leaking from the filter.
I have had 2 trailers now with that filter, and it's the first modification I made before ever running water through the units, bypassed it and use a filter outside instead...it can leak all it wants out there, at least it won't do damage.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 02-02-2017, 07:53 AM   #5
Definitely the top picture is what I need. I guess I need to do some searching on bypassing..... this is exactly the help I needed! Thanks!
Old 02-02-2017, 08:21 AM   #6
fonzie's Avatar
Here is good thread on water filter by-pass....
http://www.forestriverforums.com/for...ass-96986.html
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
water, water filter
