12-16-2018, 08:50 AM
#21
Originally Posted by Wayne O
That looks like exactly what I need. Thanks. I'll stop by my local Camping World to see if they have it in stock or if I need to order online.
Yep... that should do it.
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=15
12-16-2018, 09:17 AM
#22
Walmart carries Camco Rhino extension sewer line kits, too. CHEAPER!
I'm a bit confused. Are you needing to drain from two sewer dump valves? Is one just grey water (no solids)?
An option, once you get your main length problem solved, is to use fitting at one of the dump outlets or in ground inlets that also has a garden hose fitting. There are dump drain caps available with the garden hose fittings. Then connect a garden hose from the grey tank to the other fitting. Smaller, easier to deal with than wyeing 4" sewer hose.
2019 Cherokee Wolf Pup 16BHS flipped axle
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, TBC, Tow Mirrors, 3.55, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
12-16-2018, 12:13 PM
#23
Canadian Member
The orange fittings all come off the brown hose. You just need to turn the black locking part the right way. One way tightens, the opposite loosens. Then you can attach another fitting of your choice, including that swivel coupler.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
12-16-2018, 12:24 PM
#24
Canadian Member
Wayne O, if there is a single dump pipe at your site you may need both the swivel coupler and the wye fitting. The swivel coupler would be needed to join 2 hoses where one of your tank drain ports is more than one hose length away, and the wye fitting would be needed to connect the shorter hose from the other drain port to the longer hose, and then another short hose from the wye to the 90 deg bend at the dump pipe.
12-16-2018, 12:31 PM
#25
I had A similar issue and wanted to convert that hose into an extension hose. I unscrewed the fitting that came on the hose and then screwed on the preferred fitting which I ordered from Amazon, the third fitting pictured by the OP.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
12-16-2018, 01:31 PM
#26
Originally Posted by CedarCreekWoody
I had A si,solar issue and wanted to convert that hose into an extension hose. I unscrewed the fitting that came on the hose and then screwed on the preferred fitting which I ordered from Amazon, the third fitting pictured by the OP.
As I said in the original post, that fitting doesn't work.
12-16-2018, 01:34 PM
#27
Walmart's extension kit is only 10 ft. long just like the ones found elsewhere.
The two sewer dumps have grey and black.
12-16-2018, 01:36 PM
#28
Originally Posted by rmanduch
The bottom of my t locks into the donut that connects in the ground and I have 2 90 degree clear units that lock into both sides of the T so I can see from both lines
When connecting the two lines to the T, the T would only be halfway to the dumping port.
12-16-2018, 01:44 PM
#29
This is what purchased. I thought it was what you pictured, but perhaps not:
Valterra F02-3108 EZ Coupler Bayonet Fitting https://www.amazon.com/dp/B0006MRS7U..._2TPfCb64SGYN6
Andersen hitch
12-16-2018, 01:52 PM
#30
This is what I did.
I bought enough hoses and fittings and made what I needed. I have three extension hoses if the inground port is far away.
12-16-2018, 01:54 PM
#31
You can buy just the hose or just ends at better camping outlets  costs more though.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
#32
I've had dumping ports at various campgrounds located anywhere from the front of my rig to behind the back of my rig so I carry enough hose to attach end to end if necessary to accommodate. I personally like the T because in many hook ups I only need to use 2 hoses instead of always needing 3 with the Y. It's easier keeping all waste going down hill for me. To each his own. What ever works, great.
12-16-2018, 02:09 PM
#33
https://www.etrailer.com/RV-Sewer/Ca...xoCvKoQAvD_BwE
Think you would need to take one "L" off and replace with a new fitting.
1966 Mustang GT
1986 Mustang SVO
12-16-2018, 05:15 PM
#34
Canadian Member
For some options, here is a page showing all the RhinoFLEX kits and parts you can get:
https://www.etrailer.com/s.aspx?qry=Rhinoflex
This is the page showing how that tee is supposed to be used:
https://www.etrailer.com/RV-Sewer/Camco/CAM39734.html
12-16-2018, 07:14 PM
#35
The hose won't come off the 90 degree sewer fitting, but your two extension hoses should connect to the opposite end of the hose, then connect to your RV.
12-16-2018, 09:51 PM
#36
It will come off the 90.
1966 Mustang GT
1986 Mustang SVO
12-16-2018, 10:06 PM
#37
The 90 does come off the hose. I don't have 2 extension hoses. I have 2 hoses with 90 fittings on each.
12-17-2018, 05:08 PM
#38
Just don't let this happen
2017 Freedom Express 248 RBS
2017 F-250
12-17-2018, 05:52 PM
#39
If you remove that 90 degree end and replace it with an end like I linked in post 29 you will then have an extension hose that you can link together or add other fittings. The new fitting screws on. Several people have posted similar links on this thread.
Andersen hitch
12-26-2018, 03:10 PM
#40
This would be the cheapest option https://www.etrailer.com/RV-Sewer/Camco/CAM39773.html courtesy of Oaklevel and itat.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
