New Old Dude
I'm new to the forum, new to a travel trailer (Cherokee Wolf Pup 16 PF), but spent my entire life outdoors, hunting, fishing, camping (tent), hiking, farming, etc. Following the instructions to introduce myself...hello!
I suppose I should start a thread on another area, but I'll start here and you redirect me as necessary.
I was dewinterizing the pup, filled the freshwater tank, turned all the valves as necessary on the water pump and hot water tank, let the pump run for about 70 seconds, tried the faucet, got water for a bit, then it stopped. Seeing that, I figured the pump lost its prime so I shut it down. I crawled up in the storage compartment and turned the valve to the short hose (the one that would normally go into a jug of anti-freeze) and put it down into a bucket of water. Had my wife turn on the pump, could tell it was sucking water out of the bucket. She turned it off. I turned the valve back to the freshwater tank and told her to turn it back on. It ran for a few seconds, then seemed to struggle and finally was pumping super slow (took all of about 7 - 10 seconds) so I asked my wife to turn it off. For a while, it wouldn't even come back on. I figured I blew a fuse...nope. Then I thought may an in-line fuse (orange thing on the wires looked like it would contain an in-line fuse). Before I could open that up, I tried it again later than evening just to listen to see if it would try to come on and it did! I turned it right off. I don't want to burn it up. The pump never got hot. Any ideas of what's happening? Thanks. Chris.
