Old 07-02-2015, 11:11 AM   #1
New to RV- Water Filter and Sanitize questions
Hello! First time owner of a RV, we have a 2009 Rockwood Roo. I am trying to sanitize the fresh water and have filled it and ran the water through the faucets. After it sits a little longer, how will I drain the bleach water out so I can put fresh water in?
Second question, I need to turn my water filter on and can't budge it. It is in the "bypass" position and will not move. Any suggestions?
Thank you!!
Any help is truly appreciated!!!!!
neumannm is offline   Reply With Quote
Old 07-02-2015, 12:51 PM   #2
bikendan's Avatar
You can simply open the FW tank drain, then fill with fresh water,
Run the new water thru faucets until you're satisfied they've been flushed,
Water filter has no on switch and bypass valve is for water heater.
Unless you or preview owner installed an aftermarket bypass.
I have a 2007 Roo 23SS.
Equalizer WDH
Old 07-02-2015, 01:14 PM   #3
Ford Idaho's Avatar
Be sure to open all low point drains and the outside shower if you have one.
If you are trying to open the filter canister there might be a plastic wrench someplace.
Old 07-02-2015, 01:17 PM   #4
RE. the water filter, if you are saying it won't turn, open your kitchen faucets. This should relieve the pressure it so it will turn.
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018, 38 in 2019
CNYCamper is offline   Reply With Quote
Old 07-17-2015, 09:53 AM   #5
Summer2Go
Summer2Go's Avatar
Which way do you turn it? Clockwise or counter clockwise? I feel too much resistance, so maybe am going the wrong way?
Summer2Go is offline   Reply With Quote
Old 07-17-2015, 10:21 AM   #6
Summer2Go
Summer2Go's Avatar
Well I got it! The book says counter-clockwise, but I am pushing the wrench from right to left to un-screw. I think the book is wrong on my Roo. I made notes so I remember in a year from now.
Old 07-17-2015, 10:22 AM   #7
TGR
TGR's Avatar
My water filter canister cover spins off counter-clockwise. I have a plastic wrench that slides on from the bottom and gives me added torque.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 07-17-2015, 10:25 AM   #8
Summer2Go
Summer2Go's Avatar
-and the sucker is really snug. I don't see how they could jiggle back out. I have a 2016, maybe they did something new to fix the problem of filters coming off and spilling water all over???
Old 07-17-2015, 05:49 PM   #9
Georgia Rally Coordinator
aceinspp's Avatar
Make sure when you use the wrench to put it up as high as you can on the canister and hold top with other hand to avoid breaking the water lines. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 15
Old 07-18-2015, 02:08 PM   #10
Summer2Go
Summer2Go's Avatar
Day 2 of my water filter change. So glad I am trying everything out at home in my driveway! Can home from the grocery store this morning, and decided to put a few things in the trailer. To my surprise there was water all over the place. I checked the grey water tank, and it was full, and the shower was full and beginning to overflow. I quick turned off the hose and dumped the grey tank. We aren't even using the water, so how did the grey tank fill since yesterday putting in the filter for the first time? If nobody has any ideas, I guess I will take the filter off and try again.
Old 07-18-2015, 02:31 PM   #11
aceinspp's Avatar
Unless the city water was hooked up wrong it should not have happen. Hope the pluming is not reversed. Later RJD
Days camped 2019 62
Days camped 2020 15
Old 07-18-2015, 03:05 PM   #12
TGR
TGR's Avatar
Before going any further, I would try to find out how the water got into the gray-water tank. My hope would be that an open faucet overfilled the gray-water tank. Also, if the shower faucet cracked from freezing, defect or over tightening it could allow water to flow down the shower wall and fill the tank through the shower drain even with the faucet turned off.
To fill the gray water tank, water has to be flowing down one of the drains leading to that gray-water tank. I would empty the tank and look for the problem before taking out the filter.
Old 07-18-2015, 03:09 PM   #13
gashog's Avatar
The only way water can get to the grey tank is through a sink and shower drains. Do you have an outside kitchen? One of my friends has a Wildwood with the outside kitchen. Some how the faucet in the outside kitchen was turned on and he didn't know it. It unknowingly ran and filled the grey tank and flooding his trailer...
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 07-18-2015, 03:51 PM   #14
Summer2Go
Summer2Go's Avatar
I don't have an outside kitchen, just an outside shower. I may have left the outside shower on a bit, but the shower head was on the ground. I also had the inside shower head on the floor, maybe the head was off with the faucets on, and it filled the grey tank over a period of maybe 16 hours? I find that hard to believe. It's really strange that I fought with the filter for the first time yesterday.
Old 07-18-2015, 03:58 PM   #15
aceinspp's Avatar
Has nothing to do with filter. Shower on out side does noting just the one inside would fill the tank. Later RJD
Days camped 2019 62
Days camped 2020 15
Old 07-18-2015, 07:29 PM   #16
Summer2Go
Summer2Go's Avatar
Yeah that's what I thought, just doubting myself and totally lost for a reason. Maybe the "trickle" from the shower head did it.... hard to believe.
Old 07-18-2015, 08:42 PM   #17
Summer2Go
Summer2Go's Avatar
Turned the water back on ......no water on anywhere...... Watching the grey water tank...... No leaks.... I'll know tommorrow for sure. Just gotta watch for the big black bear going for my garbage cans by the deck....and I'm an hour from NYC in NJ. I will check in the AM, if the grey water is full again I'll suspect something other than my shower.
Old 07-19-2015, 06:49 AM   #18
Summer2Go
Summer2Go's Avatar
And no water in the grey tank this A M either. I will watch leaky faucets from now on!
Old 07-19-2015, 07:07 AM   #19
nomad297's Avatar
If you are turning the wrench from right to left, you are turning the filter housing counter-clockwise.
Bruce
Old 07-19-2015, 11:53 AM   #20
Summer2Go
Summer2Go's Avatar
But if I were viewing the canister above it would be clockwise........from the floor looking up it would be counter-clockwise. Very confusing on a filter that I have to squeeze through an outside storage door to get to. I can barely fit an arm and a head in the opening, let alone 2 arms. And I can't get close enough to see with my glasses. I get it now, and will remember for next time.
water, water filter
