Old 04-30-2017, 06:59 PM   #1
Newbie question on water
So I'm new... Been camping twice... Love it. 2002 36 ft Natl Dolphin... Great shape ... Have something I don't understand. So each time I disconnect from city water and tried turning the pump back on and use water from the fresh tank... It takes a long time to get water... I can hear the pump running ... Am I doing something wrong? Or do I have a problem?
Thanks in advance..
Robbie
Bigblueoval is offline   Reply With Quote
Old 04-30-2017, 07:14 PM   #2
tuckerdog1's Avatar
You do have water in the fresh water tank, correct?
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
Remember those that died for us. And remember who killed them.
tuckerdog1 is offline   Reply With Quote
Old 04-30-2017, 07:54 PM   #3
Yes.... I have a couple of theories... When I connect to city water (with a pressure regulater). I have a small drip somewhere behind the outside panel... When I disconnect everything and run off the tank ... I hear the pump running and have "some" water, but no pressure and there is a considerable amount of air. Also, isn't the pump supposed to build up pressure and shut off? Mine never shuts off. Is it possible this "leak" is preventing the system from building pressure?
Old 04-30-2017, 08:03 PM   #4
Yes the pump should build up pressure and shut off. If it's not and your fresh tank is full you have a leak or a clogged pick up
Jmkjr72 is offline   Reply With Quote
Old 04-30-2017, 08:56 PM   #5
Thanks... I'm gonna check on the leak tomorrow .
Old 04-30-2017, 09:00 PM   #6
Mr. Dan's Avatar
Do you have a valve you can turn to allow the pump to draw in anti-freeze for winterizing? I've seen (in person) that valve be partially turned such that the pump sucks air through that input hose. You can test that by sticking your anti-freeze hose in a jug of water while the pump is running.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 04-30-2017, 09:11 PM   #7
I'm. Not sure... I will check that tomorrow also.
Thanks!
Old 04-30-2017, 09:12 PM   #8
SeaDog's Avatar
Let the forum know what you find and how you correct it
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-01-2017, 12:46 PM   #9
Tom48's Avatar
Or some sand breaking the seal in the diaphragm chambers of the pump.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 05-01-2017, 03:19 PM   #10
I would agree with Tom48's response.
Robertpaul is offline   Reply With Quote
Old 05-01-2017, 08:02 PM   #11
SailorSam20500's Avatar
Any chance the prior owner installed a pressure tank in the water system?
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 05-01-2017, 08:21 PM   #12
You do realize that connecting to city water does not fill the fresh water tank, right? It is a separate step to place the hose in the fresh water tank fill port to fill the fresh water tank.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 05-01-2017, 08:38 PM   #13
sgtlm17's Avatar
Yes you have water in your FW tank?
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-02-2017, 05:10 AM   #14
How long is the delay? It does take awhile for the pump to prime it self. It is 15 years old , they have improved, how does it work after you get water? Enjoy ��
Big Bill is offline   Reply With Quote
Old 05-02-2017, 05:48 AM   #15
Side note: Don't ignore the "small drip", find it and fix it.
johnbryanpeters is offline   Reply With Quote
Old 05-08-2017, 09:53 AM   #16
But to answer part of your question . . . if your tank has water in it, you should get water in a short period after removing the outside water source. A lot of good troubleshooting suggestions above. You do need to find out soon so damage from a leaking pipe is kept minimal if that is the issue. Good luck and let us know.
texasbuckeye is offline   Reply With Quote
Old 05-08-2017, 09:59 AM   #17
Not always...
Many units fill the fresh water tank by connecting to the city water port and then turning a valve that switches the plumbing, thus filling the fresh tank. No separate fill port on these units.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 05-09-2017, 12:11 AM   #18
wvufan1958's Avatar
"All very good answers.. yea no leaks . Hope you find out your problem. Safe travels ))))
wvufan1958 is offline   Reply With Quote
Old 05-09-2017, 01:19 AM   #19
OP has Not been back since 4/30/2017! No other Input! Youroo!!
Old 06-03-2017, 07:38 PM   #20
Sorry for the delay..... The leak and the pressure problem was due to an old leaky pump... Replaced the pump... All good now.
newbie, water
