Old 12-07-2016, 03:21 PM   #1
billkaz
No flush water in toilet
When the flush pedal is partially down, no flush water enters. The toilet is a Dometic 300 model with a foot pedal for flushing. The pedal does open the drain ok when fully depressed. Any thoughts on repair?
billkaz is offline   Reply With Quote
Old 12-07-2016, 04:39 PM   #2
rracer5's Avatar
Does any water come in?
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-07-2016, 04:50 PM   #3
A common complaint on this model toilet is there is a screen at the inlet where the supply line attaches to the pedal/valve.
The screen gets clogged and no water flows when depressing the pedal.
Most have said it is very hard to see the screen unless you take a mirror and use to see back inside the valve once the line is off. Blowing out with compressed air (duster can or compressor) usually fixes the problem.
Days Camped: '17=30 '18=51 '19=58 '20=83
water
