The check valve is the brass fitting coming out where it says HOT.
I THINK your valve is in the Bypass position in the pic, but it's not always clear where the handle should be; but you should try it both ways.
If you still have a problem, it may be the check valve isn't opening, or some other issue.
(Have you verified the WH is full? Open the T&P relief valve and make sure you have water coming out. If no water comes out, turn the valve the other way and try again.)
2011 Traverse LT, 3.6L, FWD
