So my water pump burned out on my 2020 NOBO 19.1, and I think I found the problem, small pebbles, and sand in the fresh water tank.
What will happen is the shower water will run fine for a little while and get slower and slower to the point it trickles out. However, when I run a different faucet, it comes out good . Take the shower or faucet apart and see if you got rocks in it. Thats what happened to me, and it did eventually ruin the pump. I now carry an extra pump with me, at $50 on Amazon, when it goes, it just goes out on you right away, ruining your trip and its a 30 min or less repair if you have the part. When I took the pump apart the metal screen filter was also full of little tiny rocks and some was making it past the stainless screen.
I am now going to install an inline filter when I get the chance as its doing it again on the new pump.
I do use the blue Walmart hose line filter but not always when filling up the fresh water tank so I got some bad water somewhere. Some of these lakes we stay at say "non-potable" on the faucets so that means the water comes straight out of the lake.
Another thing to check is the suction line is good and tight and doesn't leak air going to the pump as the pump will run continuous with if its sucking any air. It primes and then stops automatically once it builds a certain amount of pressure so any leaks would cause it to run forever.
