Outdoor kitchen hot water hose that passes thru a pvc pipe into underbelly sprung a leak. It got a kink in it when the slide goes in and after 5 years of going in and out it cracked. I wonder what hose I could use that will not kink and collapse when hose empty and not under pressure, when I pull the slide in.
About 5 feet. The fittings on each end need to be crimped on. I thought about braided. I thought about wire loom over hose to keep from kinking. It’s a bad design.
