Old 09-15-2020, 08:13 PM   #1
Ok Iím stumped
After replacing my anode rod I sanitized my fresh water system and all was good
Then I hooked up to city water with a regulator in line and the water kept running with all taps closed
I dumped my fresh water tank after cycling the water pump and have no water coming out of the fresh water drain
The city water is filling my black water water tank
Donít know how this is possible
Any ideas?
myxkp is offline   Reply With Quote
Old 09-15-2020, 08:22 PM   #2
Any ideas?
Are you sure you connected to the city water connection and not the black tank flush connection?
NavyLCDR is offline   Reply With Quote
Old 09-15-2020, 08:26 PM   #3
Sounds like you may have accidently hooked the city water to your black tank flush inlet instead of the freshwater inlet.
2016 Sabre Lite
2018 Ford F250
Pull Rite SuperLite 2600 Single Point Hitch
MichRV is offline   Reply With Quote
Old 09-15-2020, 08:44 PM   #4
Yes, I was connected to the black water flush inlet which is directly above the city water connection label
The city water inlet is to the right of the label and was obscured by the hose for my outdoor shower
So simple
I figured out my dumbness right after posting to the forum
Thanks for taking time to help
Old 09-15-2020, 09:31 PM   #5
Director, FROG
F.R.O.G.'s Avatar
Someone accidentally did that at the FROG Rally in Goshen a few years ago. It wasn't pretty. We used a forklift to move him to a dump station where he could dump.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 09-15-2020, 09:33 PM   #6
PhD, Common Sense
eye95's Avatar
Is this the RV black tank equivalent to doing the ďprepĒ the night before the ďprocedureĒ in the morning?
eye95 is offline   Reply With Quote
Old 09-15-2020, 10:03 PM   #7
My solution to prevent accidental hookup to the wrong tank, if that is what happened here.
Name:	Black Tank Marker.jpg
2020 Rockwood 2612WS
2019 Ram 2500 Cummins
Theb2b is offline   Reply With Quote
Old 09-16-2020, 12:39 AM   #8
My wife suggested red nail polish for the black tank flush
Think Iíll do that plus green on the city water
Old 09-16-2020, 01:04 AM   #9
Phat Phrog Stunt Crew
elind's Avatar
I had a Y valve to connecting my city water and black tank flush to my city water hose. I forgot the black tank valve open when I turned on the water. A hour later I had water fall off of the roof from the tank vent.. Oh crap!!
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-16-2020, 01:47 AM   #10
I really like the sticker you've got on that black tank flush. It's definitely a visual clue.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-16-2020, 06:11 AM   #11
Thatís the sticker I need!
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 09-16-2020, 07:00 AM   #12
Isn't 'BLUE' more universal for water ? Locators in our local area always use Blue paint and Blue flags for marking water lines.
TheWolfPaq82 is offline   Reply With Quote
Old 09-16-2020, 07:04 AM   #13
Mr. Hankey helps keep operations smooth when times are hectic.
Name:	Mr Hanky.JPG
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L
01tundra is online now   Reply With Quote
Old 09-16-2020, 07:04 AM   #14
PhD, Common Sense
eye95's Avatar
Our black tank flush is on the opposite side of the camper. That helps keep them straight.
Old 09-16-2020, 10:22 AM   #15
Lots of good input and the Mr Hankey decal is one of my favorites
Thank you all
