I had a really hard time getting mine connected the first time. Once I got it connected it would not come off. I finally untwisted the entire fitting, took it in to the vice, and worked on it with pliers. In the end I got it out, but had the same problem trying to re-insert it. I used a wire wheel on the hose (male) fitting, and used some lubricant in the whole thing, and everything works as it should now. I'm guessing it had a burr on it or something.
If I remember right you don't have to push the collar in to insert the hose fitting, but of course you do to release it. Also, I think pushing in on the fitting while trying to push the collar in makes it easier to release.
I'm looking for another fitting like that to make a little spigot (no hose) but I have no idea where to find that. I haven't tried a propane quick disconnect, but I'd assume it is different from that. I saw a few fittings on Amazon that might be close.
