Old 09-11-2015, 06:59 PM   #1
Rideandslide's Avatar
Outside Shower
Having had or 2015 Grey Wolf for almost a year now and until our last trip, had never used the outside shower. Even thou it has hot and cold handles, only cold water comes out. Looking at it i only see one inlet hose. Is cold water only correct ??? If so, at least it could have 2 cold water handles.
Rideandslide is offline   Reply With Quote
Old 09-11-2015, 07:21 PM   #2
Not to change the subject, but I wondered what my shower looks like, haven't used it in 3 years. Which key fits? Storage key or door key? Put WD40 on, but my keys don't seem to fit.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-11-2015, 07:31 PM   #3
Storage key. I have hot and cold in my 21rr
clutchd is offline   Reply With Quote
Old 09-11-2015, 11:12 PM   #4
Thurman's Avatar
Interesting: I had an older FR Grand Surveyor for about five years and we bought a 2015 Cherokee Freedom Express last January. While camping at a local lake the g'boys went swimming and they knew to rinse off before going inside. I heard one of the boys yell and went to see what was going on and he told me that there was hot water coming from the outside shower. Well, DUH, of course there would be hot water coming from the shower IF the hot water handle had been turned. But no, the cold water handle was wide open with hot water coming out of it. You guessed it--the hot water handle had cold water coming our of it. Actually this was a simple fix, I removed the entire outside shower enclosure and found that the hoses did have screw on type fitting to each handle. Just reverse the hoses and all has been well since. I understand that some of these hoses have a crimped on type fitting and cannot be reversed without cutting the crimped fitting off and having proper crimp fittings and a tool to replace them.
Thurman is offline   Reply With Quote
Old 09-12-2015, 08:52 AM   #5
Any reason you can't replace the keyed latch with a thumb latch?
Papa GLS is offline   Reply With Quote
Old 09-12-2015, 09:01 AM   #6
Who Dares, Wins
doc73's Avatar
Our 26DBH has hot and cold lines run to the back of the shower. Both work as they should.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 09-12-2015, 09:05 AM   #7
Arn
Arn
Should be hot & cold. Time for some warranty work if your dealer's close by.
Arn
Arn is offline   Reply With Quote
Old 09-12-2015, 09:36 AM   #8
Yep Cold showers SUCK! Youroo!!
Old 09-13-2015, 04:59 PM   #9
Thurman
You got it !!!!! Handles reversed, plenty of hot water from the cold side.
show, shower
