Old 11-27-2020, 09:00 PM   #1
Overflow or leak?
I hope you all had a great holiday. I had a strange experience today in my 2018 Grey Wolf Cherokee 29-TE. We had been camping for a week and my black water tank was slammed full. When we pulled away from the site we noticed good old urine leaking out of the underbelly. I have read all about the issues with the Dometic 300 toilet, so I thought maybe is was a bad flange seal. So I pulled the underbelly off to clean the urine away, everything looked good, (no obvious signs of damage to the tank. When I pulled the toilet off it had a slight appearance of a urine stain around it, pulled the flange off, but didn’t really notice a smoking gun. Question 1) has anyone ever experienced the tank being to full and dripping to the underbelly? Question 2) where is the black water vent pipe? I want to make sure nothing is busted there. 3) is this something that happens when tanks are overfilled? I have had this trailer for 3 years and never had this happen to me. Thanks again any help would be appreciated.
Jeremy73 is offline   Reply With Quote
Old 11-28-2020, 11:48 AM   #2
Only speculation because we have no actual experience.
It's possible that the valve leaked when you were moving it and there's a leak in the pipe that only appears when you move the rig. Anywhere in that system could have a leak that appears under overflow conditions.
Those flanges under toilets don't last long so you may need to replace it with one for your toilet model. No idea where your vent is.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 11-28-2020, 12:48 PM   #3
Another guess. When your tank is "slam full" it could leak where the toilet pipe or vent pipe penetrate the tank. The seal is most likely not water tight.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 11-30-2020, 12:04 PM   #4
found the issue
I found the culprit, it is the rubber grommet for the vent pipe, which is located conveniently under the shower. The grommet has a small gap on one side which was wet and you could tell had leaked. There's enough room for me to fix the issue. As suggested when I moved it and it was un level all the fluid went to the side of the vent and really pushed the limits of the grommet. Lesson learned. keep a better on the level....
leak
