02-11-2020, 04:39 AM
#41
Originally Posted by Sarahcat
Doesn’t that calculation presume that you are showering for 3 minutes with scalding hot water, with no mixing of cold?
See Post #4...  ...
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
02-11-2020, 10:25 AM
#42
Trailer Park Supervisor
Yep, I wasn't thinking on 8 cylinders about mixing water hot and cold. Interesting graph shows water consumption at both flow rates. The stated flow rate is at 80 psi. Obviously we don't use such high pressure, so flow rate is considerably less. I would in fact consider the higher flow rate model in this case. Not much difference between them anyway.
https://oxygenics.com/wp-content/upl..._SpecSheet.pdf
02-11-2020, 12:17 PM
#43
Originally Posted by rollscanardly
See Post #4...  ...
Touché!
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
02-11-2020, 12:33 PM
#44
Oxygenics Shower Head ?
Originally Posted by NMWildcat
Well, I assumed he was talking about the original, RV specific, one spray pattern Oxygenics head as opposed to the Fury. Seemed obvious to me in the context of this thread.
We have weight police, grammar police, so why not specificity police
We have the Oxigenics BodySpa RV. Is there a reason to toss that out in favor of the Fury, other than having multiple spray patterns? We have only used the BodySpa for one shower each. We bought our TT in late October and Winterized it in early November. We do the abbreviated showers, as described. We will be installing a replacement for our Thetford toilet with a Dometic 310 with a bidet spray attached to the seat bolts, which pre-augments the quick shower.
Ford Escape Turbo
02-11-2020, 12:52 PM
#45
We still prefer the original, one spray pattern in the RV. We do use the multi spray pattern Oxygenics in the house. Don't remember which model. Funny thing is, with all the available spray patterns, we always use just one of them
Scott and Liz - Southern NM
02-11-2020, 06:19 PM
#46
Originally Posted by TitanMike
I personally don't think one would notice the difference in volume between the two. Only about 3 cups of water per minute difference.
I'd stick with what you have and use the money on something else you really want and will return more value/performance.
NJKris also makes a valid argument about "cold showers" and small water heaters.
Correct.
02-12-2020, 03:51 PM
#47
Always Learning
Originally Posted by WFD
Those that have installed this shower head, does the tape they supply work to hold the mounting bracket to the shower wall? Or did you secure it with screws? Or were you able to use existing bracket?
I just reused the existing showerhead holder.
On my old rig, I added an extra (higher up so I could actually stand and shower) showerhead holder and used screws for that.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
02-12-2020, 08:01 PM
#48
Those walls are so terribly thin that it doesn't seen to be long before the screws start backing out and there isn't much there for them to bite.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
02-13-2020, 10:34 AM
#49
For my DW and I, the stock showerhead in our rig works just fine. Like a lot of other posts, we don't spend enough time in the RV shower that a multi-spray shower head and the like are going to make a difference. When we had one in our home, almost never did we ever change the flow pattern, and when traveling and staying in hotels again who changes the flow pattern found on most hotel showerheads?
Even when we have full hooks ups that would give you the opportunity to take longer showers both my DW and I try not to deviate from our normal routine, or, get too spoiled because the bulk of the campgrounds we stay at don't have full hook up luxury.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
03-17-2020, 04:59 PM
#50
I don't have much to compare it to because we bought the fury model and installed it right away after buying the tt. I just used the showerhead holder that was already there (like Ependydad did). It worked fine. We do occasionally change the pattern and I do like the fury very much.
Lisa and my furry kids - Cesare, Cincia, Dante, Capucine, and Scout
Chevy Express 3500 van
Palomino Solaire 251RBSS
Wherever you go, go with all your heart.
03-22-2020, 09:19 PM
#51
So, in staying with the Oxygenics discussion, is the Oxygenics Body Spa for RVs a noticeably better shower than say a stock shower head?
We're also replacing the faucet with spout to a faucet without a spout. The stocker always trickled off pressure /water while showering. Also the hose outlet for the shower hose is on top of the faucet where the stocker shower hose outlet is underneath. I figure it will give us a few more inches of shower hose.
03-22-2020, 09:35 PM
#52
Definitely better than the stock shower head. When we first replaced our old trailer, the stock shower head water just ran straight down with no stream. Oxygen tics shoots out and we love it...
03-23-2020, 09:09 AM
#53
Whitaker, your current faucet dribbles water to keep the hot water hot. I thought the same thing as you with our previous rig when the showerhead always leaked as I thought only to find out why they are made that way.
03-23-2020, 10:06 AM
#54
Ha! Isn't that the way it is? And the pattern you chose is probably the pattern put out by the fixed spray head!! LOL
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
03-23-2020, 11:21 AM
#55
I have the stock shower head and one thing I discovered was that I didn't have the faucets turned open fully.
May sound obvious but ever since I turned the hot and cold fully open, and then adjusted for temperature, I find the water pressure even on 12V to be acceptable.
The hose length is less acceptable but I can deal with that.
I've decided to put money into other upgrades and maintenance.
Chris
2006 Sunseeker 2860DS Ford V10 5 sp. Torq-Flite w Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
03-23-2020, 11:50 AM
#56
We've changed to the Oxygenics Body Spa, on our current and previous trailer's. We are quite happy with them, especially the more forceful spray that stock ones were sadly lacking in.
03-23-2020, 12:01 PM
#57
I see where several folks aren't happy with the shower head hose. Most are standard fittings and you can purchase any style, flexibility, or length you need.
Here are just a few from one source: https://www.homedepot.com/b/Bath-Bat...s/N-5yc1vZbrfn
03-23-2020, 12:39 PM
#58
Originally Posted by Fluffywhitedogs
Yea, this place has cost me a few bucks but I figure it’s saved me quite a bit, too!
Same here. Probably have spent as much as the TT cost.
Mike
 Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
03-23-2020, 12:56 PM
#59
A big difference is camp site water presure. Shower head helps but really works if you spend time to adjust how much presure you allow in I have checked my long term site and it is at 40 psi so I allow full presure in and now the shower presure is fantastic.
I do not think i would allow much more over 40 psi or need yo.
07-27-2020, 02:47 PM
#60
Resurrecting this line of discussion ...now with COVID we are showering in our camper only to stay safest possible and the showerhead sucks (in 7 yrs have probably used it only 5 times...we have always been pretty happy with CG showers).
So is the jury still out on BodySpa vs Fury model??? Looks like BodySpa adventure model sits right in the middle with 3 settings instead of 2. Tired of washing my hair off the hose cause shower doesn't have enough pressure to even begin to let me shampoo my hair.
Thanx!
Terri + Joe + BrewDog Boont
Camping a long weekend every month since starting in May of 2013 in order to practice for retirement .... Florida is a great state to have this bad habit
