Reaching out for help on an origional setup for a water line to my ice maker. I have a 2020 SIERRA 33 RLIK, had an unfortunate blowout this weekend and one item damaged was a "T" fitting on pex line that feeds the ice maker. Got that fixed but discovered a plastic pipe that the pex ran through into the under belly broken. I have no idea how this was setup. I will attach a couple of pics to maybe help in understanding what i am explaining.
I believe I may have sorted it out. There is a mangled clamp that I am thinking the pipe was attached to and it actually slides in and out of that hole in the frame not the pex sliding through the pipe. That will be a much easier fix. Sometimes we just have to think out loud.
Hi. Can you take pics of your repair. I had a blow out yesterday and it busted the same line. I installed a new elbow, but no ice is getting made. Wad hoping for some tips. Thanks
Hopefully pic is attached of the valve that controls water to icemaker. Believe when pushed in it is off and pulled out it is on. Or Viceversa
The black valve is the low point drain for the icemaker which i didn't know was there until the blow out. The white valve is the on/off water service to the icemaker.
