Old 07-21-2018, 12:03 PM   #1
Plumbing vent issues
We just took delivery of a 2019 35IK and with the gray tank valves closed, when taking a shower, water actually gurgles with force back out of the kitchen sink drains. Anyone with a similar unit having this issue? It does not happen with the gray tank valves open. I have not had time to trace the plumbing, however I do not think the kitchen sink and the shower drain into the same gray tank, so it must be some type of venting issue.
boomer116ars is offline   Reply With Quote
Old 07-21-2018, 03:31 PM   #2
Head Rambler
What is a 351K? (Yeah I went and looked at your profile, but don't make people do that )
So it's a Cedar Creek Silverback. Since it's a 2019 I'd let the dealer figure it out.
Do you have one or two vents on the roof?
The gray vents are most likely a wet vent so a clogged vent would cause that problem. If you have two vents try to figure out which is the gray tank vent and take the cap off and look down in it to see if you see anything clogging it up.
If you only have one vent do the same thing but realize that the gray vent is likely tee'd into the black tank vent so you probably won't be able to see anything unless the black vent is clogged too.
Gotta go campin!
plumbing, vent
