Pressure from holding tank, buckled floor
First time in this camper. Filled fresh tank for dry camping, noticed that there was a red rubber hose by low point of fresh tank that had water coming out of it, after filling the fresh tank. Was worried previous owner had cut off a valve from it so I plugged it. So that night couldn't use water anyway because the toilet valve had a leak. I assumed it had frozen in the past so replaced it. Done that on several occasions of other campers. Noticed that the water pump kept cycling so turned it off. 2nd night of camping full city hookup. Hooked up city water, replaced toilet valve, all good, go to sleep. In night hear noises in kitchen, investigate and whole floor is pushing up and counters are tilting due to fresh tank having so much pressure. Remove plug from red rubber hose and cap from tank and drain all. Also open fill cap on fresh tank and water was spraying out. Guessing the fresh tank check valve is the problem? Is it included in the pump or separate? What do I need to order install? Can't believe it didn't blue up crack the tank! The angle iron braces under neath are now bowed. Took an hour at 2:30am. What a night! 2017 wolfpack 315pack12
