Old 09-26-2021, 09:28 AM   #1
Problem with overflowing fresh water
Currently have 2021 Cherokee Grey Wolf 26DBH. When I arrive at my destination I go to the fill station to fill the fresh water tank. After about 15 minutes I will start to get water coming from the hose underneath so I assume the tank is full. This hose leaks the whole time I preceding to my camp site. When I get to the site itís still leaking and when I go to the control panel to check the quantity of water itís says Iím a 1/3 down already. Why is this happening?
Munter77 is offline   Reply With Quote
Old 09-26-2021, 09:32 AM   #2
Just Tryin' to Help
cboss's Avatar
Is it your fresh water tank drain?
Is there a small valve on the end? If so try to close it.
Just a shot in the dark...a pic might help.
BTW: Welcome to the forum from Upstate NY.
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1050
cboss is online now   Reply With Quote
Old 09-26-2021, 10:24 AM   #3
See attached photo
Old 09-26-2021, 11:06 AM   #4
your fresh water over fill is creating a siphon and draining out the tank . you can add a valve that you will want to keep open when filling or watch to fill and stop just as it starts to dribble out . i've had this happen a couple times and just blew into the over flow line and stopped the siphon .
MR.M is offline   Reply With Quote
Old 09-27-2021, 04:49 AM   #5
Mr. M. is spot on. Siphon effect. Put a plug or a valve on the overflow. Just remember to open it when filling or at your destination!.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 09-28-2021, 09:30 AM   #6
Boss Ox & Drovergirl
oxcamper's Avatar
X3
sometimes the overfill tube is too low in the tank and will siphon out until it reaches the end of the tube.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 09-28-2021, 04:20 PM   #7
360true's Avatar
Siphon issue
I poked a hole in the top of the overflow tube to allow air into the tube. It no longer siphons when overflow level has begun.
360true is offline   Reply With Quote
