Shortly after we purchased our current trailer, I saw SeaDog's post on installing a pressure tank and have installed the same tank. It is a 2 gallon tank. You can install anywhere in your RV where you have access to the plumbing and sufficient room for the tank, it does not need to be right next to the pump. Best to connect to a cold water pipe.
As I recall, SeaDog installed his tank horizontally, mine is vertical.
I like the 2 gallon tank, it provides more than enough water to handle a number of toilet flushes at night without requiring the pump to cycle, good for us because our pump is located directly under the head of our bed. The tank in the previous link only holds a couple of cups of water, so would cycle more often.
Here is a link to the unit I installed, though other manufacturers provide similar units.
In-Line Pre-charged Well Tanks | Water Worker
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
