Old 09-05-2021, 10:22 PM   #1
Puma 31QBBH Toilet Leak
I have a 2020 Puma 31QBBH and have a small amount of water standing around the base of my toilet.
Worked on plenty of home toilets but not an RV style.
Do these toilets have standard wax seals in them?
Is it as easy as going to the hardware store and getting a wax seal?
Or is it a little more involved than that?
Kind of surprised it is leaking so soon.
I even checked the nuts holding it to the floor. They are snug.
Just thought I would ask for advice before I pulled it off.
Sjohn8016 is offline   Reply With Quote
Old 09-06-2021, 07:25 AM   #2
SeaDog's Avatar
they are not like a toilet in a stick house. There is no wax seal normally just a foam ring because the toilet is a straight drop. tight bolts keep the toilet from wobbling. You leak is more then likely from the water line or the toilet valve.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-06-2021, 06:51 PM   #3
Thanks for the reply.
I did some digging around on replacing the toilet valve. And wow, did I find some info on the Dometic 300 model toilet.
I think rather than rebuild the existing toilet I am going to upgrade the model.
Sounds like a lot of issues with the model 300.
So I am going to measure and see what model I can put in there to replace it.
leak, puma
