Pump cycling, no leaks. Am I troubleshooting correctly?
I've been doing some driveway testing after bringing the camper out of storage. My fresh water pump is cycling every 6 minutes or so for one second. I have found no leaks anywhere, including on the ground. I've got paper towels jammed everywhere possible and none of them turn damp. The only place I haven't been able to check would be under / behind the shower or under the toilet flush pedal.
I then connected to city water with a digital volume meter attached and I don't see any measurable changes over an hour, measure to the tenth of a gallon. So I think the system is tight. Still no visible leaks in any of the usual places or on the ground.
So since I don't find water and the city water isn't measurably flowing after being pressurized, does this lead me to a possible check valve issue between the pump and the fresh water tank? Something else causing a loss of pressure? The pump itself is installed in a very difficult-to-access location so I don't want to mess with it if that's not a likely culprit.
2017 F-150 2.7L 4X4 Supercab
2021 Rockwood Roo 183
EAZ-Lift ReCurve R3 WDH
I've slept in 45 states and four provinces, but I have to start a new map for my camper!
