Old 07-23-2020, 05:25 PM   #1
Pump Losing Prime
Shurflo pump. We hardly ever have used the pump. It is a 2011 V-Lite. I can get it to prime by pushing some water into the antifreeze input. It will then pump up and stay. I can use the toilet, sink, etc and it will work. Leave it sit for a hour, it will lose the prime but hold the pressure in the lines. It primed itself in the spring with no issues. What should I look for? I checked the screen and there was a little debris that I cleaned out.
Where we park the camper in the yard is not level with the back end where the fresh water tank is at is lower than the pump. The camper is nose high. If level, should it not lose its prime?
KKonyha is offline   Reply With Quote
Old 07-23-2020, 05:40 PM   #2
How full is the water tank? If at any angle and tank low, could be that the water level is below the pickup. A lot of tanks are longer and wider than they are high. Makes it possible for there to be a considerable amount of water in the tank but all of it over in the wrong corner.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-23-2020, 05:49 PM   #3
The tank is completely full. We are going tomorrow to the camp site so I will level then and see. I am hoping that solves it.
Old 07-23-2020, 05:53 PM   #4
Had to ask.
Also, check the strainer at the inlet of the pump. Bowl may be loose and pump is sucking air. Doesn't take much to keep it from sucking up water from a tank lower than it.
2004 Nissan Titan
Old 07-24-2020, 04:17 PM   #5
Says to me the valve that selects antifreeze or tank is leaking air or is not fully in the "tank" position.
Fred W
Old 07-29-2020, 11:29 AM   #6
Fred W
Worse yet, or more embarrassing, the valve was in the wrong position. Once it was in the correct position, worked well all week-end. I am impressed that a 10+ year old pump still works even though this is only the 2nd time it has been used in its life.
pump
