Old 10-12-2014, 11:15 AM   #1
heavynlori's Avatar
Question on water pump
Used the fresh water tank for first time this weekend (have city water at seasonal)
Turned pump on - ran a short bit and stopped - normal
Fresh water Tank was full
Hot water tank full
Turn faucets on - got water thru all of them - hot and cold
Flushed toilet - works good
Set up at campground
Turn faucet on in kitchen - pump kicks on
Good pressure for about five seconds
then the longer the faucet stays on the less and less water coming out until its just a trickle - doesnt matter whether hot or cold - same result
Pump is running whole time
No shower - took forever to wash dishes or flush/fill toilet every time
Turn faucet off in frustration and pump runs for about thirty seconds until it shuts off
Pump does not run unless you open a faucet and no leaks to be found anywhere inside or outside
Any thoughts???
heavynlori is offline   Reply With Quote
Old 10-12-2014, 11:35 AM   #2
Ford Idaho's Avatar
Water faucet aerator screens clogged with debris?
Many here have reported plastic bits clogging the screens.
Also check the screen in the water pump bowl.
Old 10-12-2014, 11:42 AM   #3
heavynlori's Avatar
Nope screens all clear - worked great all summer on city water hookup
Checked all again today when we got home and still crappy pressure on using pump.....
Old 10-12-2014, 11:42 AM   #4
mcnabbwr's Avatar
If you are having the same result with all of the faucets, it sounds like a restriction on the intake side of the pump. Maybe a kink in supply hose, screen plugged or even a bad pump. Somehow there is a loss in volume to or out of the pump.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-12-2014, 11:45 AM   #5
heavynlori's Avatar
Screen in the intake to the pump??
Will try that
Old 10-12-2014, 11:47 AM   #6
VinceU's Avatar
X2 there is a very fine mesh screen in a strainer bowel attached directly to the pump. Sounds like it is gradually plugging.
Old 10-12-2014, 12:03 PM   #7
make sure the vent on the tank is clean eliminating a vacuum and there is a screen on the pump that may be dirty.
Fourn3833
2008 Georgetown SE TS
2013 Ram 1500 Longhorn in tow
Fourn3833 is offline   Reply With Quote
Old 10-23-2014, 03:18 PM   #8
heavynlori's Avatar
Update on water pump issue
Winterized camper today - found the intake hose on pump was kinked and twisted ....cut off bad section and put back on !
Ta - Dah we have awesome pressure - too bad season is over until April 1, 2015 😞
Old 10-23-2014, 04:24 PM   #9
mcnabbwr's Avatar
Glad you found the problem and got it repaired. At least it will be ready for next season.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
pump, water, water pump
