08-07-2024, 11:15 AM
Quick release
I’m thinking about getting quick release fitting for my fresh water setup. Anyone use them? Do they work well? If you don’t use them why not? If I do should I expect any noticeable water restriction?
Figure I’d put connectors on the splitter at the spigot, pressure regulator, the filters, the hose and then at the city water attachment.
F. R. Wildcat 5th wheel 333 RLBS
2019 Ford F-250
Former US Navy 6/1968 - 3/1972
Retired forensic auditor 4/2022
08-07-2024, 11:37 AM
We had a few on our lawn stuff at home and took them off, mainly cuz there was no way to release any trapped pressure. We leave our regulator on our drinking hose all of the time, usually tightend on with a set if pliers, so we don't forget it. By design, we need a 45 on our filter, going into the trailer, but we leave them apart for ease of storage.
I would guess there's a bit of a pressure drop on them, but not sure how noticeable it would be.
Camped: 2024 (Days/Nights) - 30/25
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
08-07-2024, 12:12 PM
I bought a bunch of the brass ones at Harbor Freight and could never get them to stop leaking. I even took them back and got replacements. I then bought the brass/plastic knob type at Walmart and while they have worked better, I still have a couple leakers and the water in the park we stayed at this past winter started to erode the male/female connections as well in 3 months.
I'd love to find quality ones that don't leak as they can be a time saver for all the connections you mentioned.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
08-07-2024, 02:44 PM
I found them to be convenient but all I've ever had leaked. I resort to good fittings on the end of everything. Plastic ones, nah! Brass ones, yes
If you are concerned about tightening or loosening fittings, use a shop cloth to give a better grip and protect one's hand. And please do not use pliers, channel locks, or such to tighten or loosen hose attachments. If one needs it that tight to stop a leak, one should replace the fittings internal rubber washer.
Bob
08-07-2024, 08:42 PM
I have been using solid brass QD's at home and on the coach for years I purchase them from a seller on eBay that goes by the name "PRESSURE WASHER OUTLET" they have never leaked or failed in any way. They look similar to many others but are constructed differently. They also see the replacement washers as they are not standard hose washers. I have 15 or so sets and have never needed to replace the washers in 5 years. I too tried many other types that leaked and were flimsy before I tripped across these.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
08-08-2024, 09:53 AM
James and Teresa,
DW of 32 Years.
2014 Coachmen Sportscoach Cross Country 360DL
08-08-2024, 10:09 AM
Similar to my experience
That's similar to my experience. The Harbor Freight ones worked fine the first year. The metal construction is great--showed no signs of corrosion at the end of the season. But the seal leaked after the first season and could not be replaced. I eventually discarded them all.
Larry
08-08-2024, 06:30 PM
Originally Posted by ejw7213
X2 but a different seller. Sure look the same. Been using them for two years full time camper and moving every 5-9 days normally. No leaks.
Put in a wye shut off if you want to relieve the pressure build up as posted above. That is what I do.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
08-08-2024, 08:28 PM
Which Y connector do you use?
James and Teresa,
DW of 32 Years.
08-09-2024, 06:05 AM
Just a common one like this. You can put a quick connect on both sides if you want to use both at different times. Have for mine for washing the roof, truck, etc.
I also have a shut off right before my dual filter assembly. It is installed right before my city water connection. I leave the camper area I shut it off. Yes I could use the wye but it is at the back of the camper and the filter assembly is at the front where my truck is usually parked or even just roaming around the campground I usually leave my site from the front.
Some folks here say it is a pain to shut off the water all the time. Beats coming back and finding a leak that may have sprung up while gone. Just my opinion.
2022 Rockwood 2511S
08-09-2024, 06:50 AM
Haven't any desire to try a quick release. Tried them several years ago always leaked................ Just as easy to use a tried and true screw on type.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
