R-pod water problem
Own a 2016 R-Pod. Just connected water after a few months of unit in storage. Cold water to kitchen sink not flowing. Hot water does. Water flows to bath sink and outdoor shower. Tried using water pump to flush. Cleaned faucet filter. Also opened low water drain. There is a white creamy substance that was at the low water (cold) drain. Ditto for faucet filter. Clearly this substance is blocking cold water flow to sink.
Should I add additivetodissolve? Blow out using air pressure? Any advice appreciated.
Thanks, Ken
