Old 05-29-2020, 12:39 PM   #1
Really weird plumbing issues with a new to us 2056 mini lite
I can hook up city water, or use the pump and get a GREAT stream at the shower, a very weak trickle out of the kitchen sink, and NADA at the out of the bathroom sink, outdoor kitchen, outdoor shower. And to top it off, the toilet ALMOST overflowed, and the fresh water valve at the foot valve is leaking a little....
Is there a valve in the innards of the trailer that I am missing?
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
Half Ton Heavy is online now   Reply With Quote
Old 05-29-2020, 07:19 PM   #2
larry2c's Avatar
I haven't seen any valves or regulators internal to the plumbing in any of our TT's (other than the ones for winterizing). I have found kinked PEX tubing which will really kill flow and pressure. You could also check all the faucets aerators if they have them - they can get gunked up and reduce flow.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is online now   Reply With Quote
Old 05-29-2020, 07:22 PM   #3
Itís going to the dealer next week to get sorted out.
I have to think they are going to have to drop the liner on the bottom to sort it out. Such a bizarre problem!
2018 Rockwood 2506
Old 05-30-2020, 09:53 AM   #4
Yep. Faucet aerators would be first thing I would take off to check for debris
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 05-30-2020, 09:56 AM   #5
As far as the toilet is concerned, those likely came with dometic 300. They had different issues than what you are having but you can call dometic and they will replace with a 310 model. Your problem is actually going to be debris in the valve holding it open. The valve itself is cheap and easy to replace.
Old 05-30-2020, 11:11 AM   #6
rracer5's Avatar
If not debris in ALL of the affected faucets (highly unlikely) then I suspect a kink in the line AFTER the "T" to the shower. But, wait.....are BOTH hot & cold affected or just 1? If both then, I'm stumped too.
2014 Sanibel 3250
rracer5 is online now   Reply With Quote
Old 05-30-2020, 12:11 PM   #7
Yeah, that's the confusing part for me too. Hot or cold not working, but both? Like I said, weird. Just dropped it off at the dealer.
2018 Rockwood 2506
Old 05-30-2020, 02:26 PM   #8
$75 credit
I've heard (on this forum) that Dometic is currently only giving a $75 credit towards an upgrade from a 300 these days, and only if you indicate that you smell urine and believe it is collecting between the two parts of the bowl.
Just wondering, Babcock, how you concluded that the OP had a Dometic 300.
Larry
Larry-NC is online now   Reply With Quote
Old 05-30-2020, 02:35 PM   #9
He's absolutely correct, crappy plastic toilet that will likely get changed soon.
2018 Rockwood 2506
Old 05-30-2020, 04:07 PM   #10
That's what comes standard in his year Rockwood
Old 05-30-2020, 06:37 PM   #11
Tundra 2014
Water
X-2 I would check the aerators on sinks. A small amount of trash in the lines will stop them up. Especially on a new trailer from construction trash left in the lines. Make sure all the cut off valves are parallel w/ water lines, except on the outside Anti-Freeze feed, if you have one. I agree the next thing to look at would be a kinked supply line.
Tundra 2014 is offline   Reply With Quote
Old 05-30-2020, 07:53 PM   #12
Pretty sure it had a heart attack of some kind.
I unscrewed the outdoor shower head, and tried to force some compressed air down the hose with both valves open. It spit back at me a bunch of what I believe to be calcium. I also noticed a bunch of calcium on the connection point of the shower head.
This has me concerned, because finding the plug may not be easy without tearing the bottom up. If it was not at the dealer ( the seller graciously agreed to pay whatever the repair is) I think I would try some sort of acid solution. The trailer is only three years old, I cannot imagine what water would be so saturated with calcium to have deposits like that.
On the other hand, maybe it is just some kinked pex or something. Again, super strange that hot AND cold are both equally affected yet the shower and toilet work great.
2018 Rockwood 2506
Old 05-30-2020, 11:24 PM   #13
Tundra 2014
Water
If you are seeing that much calcium, take the plug out of your hot water heater. Get one of the hose end heater cleaners $8WM-and spray inside it for a while. After this try spraying some Lime-A-Away in it -put the plug in over night and rinse and repeat.I would take the aerators off and run water thru them 1 at a time.Might soak them inn Lime-a Way overnight also. I rinse my water heater ate the end of each season and check the anode-if a Suburban WH. Always surprises me what comes out.
Old 05-31-2020, 01:31 AM   #14
I agree it is probably the screen aerator on the end of your kitchen and bathroom sinks. Donít know your water quality or the water quality of the previous owner but depending on the water you supply to the water heater can cause a lot of fine calcium in the water when heated. This will plug the fine screen in the faucet output. Unscrew the screens on the faucets and see what happens when you turn on the water.
Also, drain your water heater and clean out all the calcium buildup. There is a tool for this that connects to your water hose.
I guess if it is at the dealer they will take care of it. Hopefully you have a good dealer and it wonít take a month for them to get to it..lol..
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 05-31-2020, 06:52 AM   #15
Very common issue if WH NOT put in bypass BEFORE opening Low Point Drains! The WH CRUD drains through the Water System! Isolate the WH and Drain by its own Drain plug! Youroo!!
Old 05-31-2020, 09:49 AM   #16
Utah Traveler's Avatar
Water Heater
Once and only once did I remove the water heater to flush out the calcium in it.
Problem is, I did not isolate the heater using the shutoff valves.
Result was every faucet and toilet receives a large dose of debris.
PIA to clean out. Never again will I make that mistake.
Utah Traveler is offline   Reply With Quote
Old 05-31-2020, 09:55 AM   #17
Sorry, what I meant was I removed the plug from the water heater.
Old 05-31-2020, 08:41 PM   #18
They said they are pulling it in (dropped off already) in four days this coming Thursday. I will absolutely report back on what the issue was.
Hopefully they have some good, competent techs!
2018 Rockwood 2506
Old 06-01-2020, 05:00 PM   #19
dbledan's Avatar
Yeah, I think this is the problem. I did this once....same issue. Every fixture I ran got pieces of the annode and crud stuck in them cutting the flow...luckily it did not happen to the toilet only the sinks and showers so easy fix.
dbledan is offline   Reply With Quote
Old 06-01-2020, 06:55 PM   #20
Thanks mate! Hopefully a quick, cheap fix! I did remove the outdoor shower head and got nada though. So that is plugged somewhere further up the line.
2018 Rockwood 2506
lite, mini lite, plumbing
