Old 04-30-2017, 11:35 AM   #1
Refilling and emptying black tank/city connection
Hi all, I have a 2014 Wildwood trailer, and as far as I can tell I do not have a hose connection to refill and flush the black tank in an effort to keep everything clean. I know to close the grey line for 24 hours, drain the black tank, and then release the grey tank. I wanted to flush the black tank again now that I have my clear adapter hooked up to see if the black indeed has been emptied thoroughly. My question, am in a campground, so hooked up to the city line: if I do not have a line to refill the black tank, do I just use the toilet for water to refill so that I can flush again? As always, thanks for your help!
Joe
joetab1977 is offline   Reply With Quote
Old 04-30-2017, 11:54 AM   #2
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Joe
I attach this Flush King to my sewer hose and then to my camper...Valterra
F02-4350......It allows for a backflush of the black tank ......Close grays...open black....attached water hose....I have one set of hoses dedicated for this purpose...I also attach a backflow preventer adapter to the hose and faucet.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi...
2017-65 nights/6992 mi.; 2018-47 nights/7376 mi; 2019-65 nights/7825 miles; 2020-7 nights/562 miles/6 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 04-30-2017, 11:57 AM   #3
Forgot to post pic for above comment.
Old 04-30-2017, 11:57 AM   #4
mjones12's Avatar
F02-4350......It allows for a backflush of the black tank ......Close grays...open black....attached water hose....I have one set of hoses dedicated for this purpose...I also attach a backflow adapter to the hose and faucet.
X2. I think that would be a real good choice. Used one for years.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-30-2017, 11:59 AM   #5
NMWildcat's Avatar
Flush King is a must have for back flushing tanks IMO. I use one in conjunction with my auto flusher.
http://www.valterra.com/product/flus...h-valve-boxed/
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 04-30-2017, 12:10 PM   #6
BooBoo23's Avatar
I don't have a black tank flush. I have a device similar to the Flush King, different manufacturer and I also use a flush wand. It works best for getting the tank cleaned out. Here is a You Tube video of it.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 04-30-2017, 12:40 PM   #7
NMWildcat's Avatar
Just a mention that the flush wand does an excellent job, but has to have a straight shot from the toilet to the tank. Most folks in our group have an elbow fitting at the toilet.
Old 04-30-2017, 12:53 PM   #8
You can get a flexible wand for those toilets that have a bend in the sewer pipe; Flexible Tank Wand - Valterra A01-0187VP - Sewer Flushing - Camping World
Pipeman is offline   Reply With Quote
Old 04-30-2017, 01:28 PM   #9
NMWildcat's Avatar
This wand might actually be long enough to reach my tank and go through both elbows. I'll have to check it out. Thanks!!!
Old 04-30-2017, 07:29 PM   #10
I did add the clear adapter. It does not have an opening for a hose. As far as a wand, not sure if I would need a flexible one. Guess I need to get underneath to see the connections. Or does the bend in the pipe visible in this pic, mean that I would likely need a flexible wand?
https://drive.google.com/file/d/0B5y...ew?usp=sharing (since this pic, I have added a clear extender)
Old 04-30-2017, 08:08 PM   #11
deartruc's Avatar
I installed this on mine last year:
https://www.amazon.com/Camco-40126-T.../dp/B000BUU5TU
Before I installed it the black tank lights never would read correctly.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 05-01-2017, 04:29 PM   #12
I use a Y at the faucet with two dedicated hoses, one for city water to the RV and one for the black tank flush. I flush the black tank each I time drain the black tank.
bajamike1 is offline   Reply With Quote
Old 05-01-2017, 04:42 PM   #13
Scoundrel
HangDiver's Avatar
You should be able to look down the toilet drain pipe and tell if you have an elbow or if you can see straight down to the black tank.
HangDiver is online now   Reply With Quote
Old 05-02-2017, 11:39 AM   #14
DouglasReid's Avatar
One Word of Caution!
I would like to caution you if you are using any device to refill your black tank to flush it with the toilet not being held open, as in when using the wand from above the toilet.
Be SURE you monitor the tank level and quit when it just gets to the full mark on your indicator. This forum is replete with stories of people who did not, walked away and "forgot" it was filling. The resulting pressure caused the tanks to split or worse, fall off of their mounts creating a very messy situation and very expensive repair.
Im NOT saying not to do it, just be careful. this warning applies to factory installed flush systems as well!
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
black, black tank, tank
