Old 04-10-2017, 02:24 PM   #1
refrigerator door falling off
Hi all,
We have a 2014 hemisphere light 5th wheel and have had a few problems with the dometic AC - now replaced, and now with the dometic refrigerator door falling off twice and the freezer door falling off once in the past 9 months. Seems the plastic hinge on bottom of the door that fits over the hinge pin breaks and the doors comes off. Each time this has happened the 5th wheel has been parked at our home, I walk into the RV and there are pieces of the plastic hinge part on the floor. The door has been closed shut each time, no one swinging on the door or anything like that. Anyone have any ideas as to why this has been happening?
Mark Smith
marasmith is offline   Reply With Quote
Old 04-10-2017, 02:36 PM   #2
Do you have the door overloaded with stuff?
SidecarFlip is offline   Reply With Quote
Old 04-10-2017, 02:38 PM   #3
Refrigerator and freezer both were empty and not in use. 5th wheel was parked at house - not in use.
Mark Smith
Old 02-29-2020, 12:11 PM   #4
We have a 2016 Flagstaff T21TBHW A-Frame camper. This past week the refrigerator door fell off. It appears the top hinge pin has "wobbled" out the top plate hole OR some plastic "sleeve" has broken leaving the thin metal pin in place. This situation now allows the door to lean outwards causing strain on the remaining plastic components. Has anyone else experienced this problem and what was the fix?
2016 T21TBHW
2017 Ram 2500 CTD CC SB 4x4
Ortep is offline   Reply With Quote
Old 02-29-2020, 12:25 PM   #5
Flybob's Avatar
Might try this site.
https://www.thedometicguy.com/parts-by-dometic-model/
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-29-2020, 01:15 PM   #6
Thanks Flybob.
2016 T21TBHW
door, refrigerator
