Old 04-10-2017, 07:44 AM   #1
Replace pressure gauge or buy new pressure regulator?
I have use a Valterra water pressure regulator with the liquid filled guage for about 4 years now. It has worked great but I left it in the RV over the winter and now it reads 100 psi even without being hooked up to the water.
So my question is, should I/can I just put a new gauge on it or replace it entirely? Any recommendations on a gauge if it can be replaced?
Thanks.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 04-10-2017, 07:46 AM   #2
lozki's Avatar
Just replace the regulator it will be easy and solve your problem
lozki is offline   Reply With Quote
Old 04-10-2017, 08:05 AM   #3
Mr. Dan's Avatar
I'm guessing the OP doesn't want to spend another $55-60 for the complete unit.
Yes, I think I've seen oil-filled gauges being sold to screw into the original regulator.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 04-12-2017, 11:39 AM   #4
Head Rambler
Those Glycerin filled gauges are pretty cheap on Amazon and other places. You just need to know the range and the fitting size. It's most likely 1/8" or 1/4" npt. The case size isn't really important unless it has to fit in a recessed niche.
Gotta go campin!
pressure
