Old 12-27-2020, 06:41 PM   #1
Replacement 52 gallon black water holding tank
Hello, I have a 1999 Sandpiper 5th wheel. I need to replace the ruptured 52 gallon black water tank. How do I find out the tank model number so I can order it?
Thanks!!
Poppy56 is offline   Reply With Quote
Old 12-27-2020, 06:46 PM   #2
Always Learning
When I had a gray tank replaced on my camper, the repair center opened the under belly and wrote down numbers that were literally hand-written on the side of the tank. I then found some internet site that had tanks. It was cheaper through them than what tbe repair center could acquire it.
So, first step- get eyes on the tank.
Old 12-27-2020, 06:49 PM   #3
Hey there are some numbers hand written on the tank. Must be them? Do you remember how many numbers?
Old 12-27-2020, 09:22 PM   #4
Always Learning
Apparently I emailed the service center photos. Hereís what I had (mind you, mine is a different camper and different capacity, these are for guidance only).
ID:	245124   Click image for larger version
Old 12-27-2020, 09:33 PM   #5
Thanks so much. I will check out the numbers on my tank and hopefully find a replacement online somewhere.
Old 12-28-2020, 01:38 PM   #6
Some possible sources
Thanks!!
Some possible sources:
https://www.camperid.com/black-water-tanks.html
https://www.plastic-mart.com/categor...-holding-tanks
https://www.icondirect.com/waste-hol...roup=51-55+Gal.
Larry
Larry-NC is offline   Reply With Quote
black, black water, replacement, tank, water
