I wouldn’t consider replacing connections that don’t leak with other connections that don’t leak an upgrade. Now if you were having failures, then maybe. I’ve replaced faucets in both my house and my MH when things have failed and although the majority of the connections were made with PEX cinch clamps, none have ever failed. It’s always the faucet or the house bib, etc., never the clamp.
That system has a couple of things going for it. The tool is cheap. $50-$60 if you look. The clamps are cheap and proven. But most importantly, the tool head is small and it’s the easiest of all the systems I’ve used to get into tight quarters like you’ll find in an assembled MH. New construction, use what ever, but remodel or repair, when you have to reach in and maybe even use just one hand, I’ll take the cinch clamps. My $.02.
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
