Old 10-19-2020, 06:54 PM   #1
parkerkevin65's Avatar
Rhino Fitting at gate valve Leaks
Hello all!
I use the rhino system and Iíve noticed that when I first pull open the gate valve for my black tank I get some leakage where it connect to trailer, it falls to the ground and this mostly happens right after I pull the valve and thereís more pressure and more flow.
Iíve tried everything to stop it. Has anyone experienced this with the rhino fittings?
Thanks!
parkerkevin65 is offline   Reply With Quote
Old 10-19-2020, 06:59 PM   #2
Just Tryin' to Help
cboss's Avatar
Replace your gaskets (O rings). Here's the male and female:
https://www.fleetfarm.com/detail/cam...saAoeCEALw_wcB
Also available from many other sources.
In the mean time a little vaseline might help, but gasket replacement is the best.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 870
cboss is offline   Reply With Quote
Old 10-19-2020, 07:05 PM   #3
Enjoying Life
X2
Also available on Amazon
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
ďLife should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!Ē - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is offline   Reply With Quote
Old 10-19-2020, 07:10 PM   #4
Just Tryin' to Help
cboss's Avatar
Originally Posted by TeachTexas View Post
X2
Yep Amazon. That is normally my go to , but just was looking for the fastest place
I could find...LOL.
Craig & Cath
Old 10-20-2020, 07:33 AM   #5
Funengineer's Avatar
I experienced the same type of thing last trip out. Gaskets were good but it seamed to leak from the hose and fitting. Unlocked and backed off the fitting collar then screwed the hose onto the fitting tighter. Tightened the fitting collar and no more leak.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
Funengineer is offline   Reply With Quote
Old 10-20-2020, 09:33 AM   #6
^^^^^^ This.
O-rings are the obvious but less obvious is the actual connection between fitting and hose. Rhino makes it easy to fix as described above.
Also, for those who might arrive in a site that has weird sewer hookups that don't accept conventional hose fitting/elbows (like WA State Parks along the Coast) the Rhino fittings can easily be removed and the hose then inserted in their non-standard cast iron elbows. Don't have to mess with hose clamp and trying to get fitting back into end of hose.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-20-2020, 01:05 PM   #7
PSUFan1's Avatar
I had the same issue and replaced the o rings and now all good. Got mine at Camping World.
Tim & Tracy, Jennifer (17), Alyssa (13), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
leak, valve
