Old 04-22-2017, 05:04 PM   #1
Roo water filter
I have a 2017 Roo 233s. I just finished sanitizing the system. Now it is time to put in the water filter. I can't get the housing off though. How easy should it turn? Is there a secret to getting it off?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is online now   Reply With Quote
Old 04-22-2017, 05:47 PM   #2
deartruc's Avatar
Make sure you relieve the water pressure by opening a faucet.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 04-22-2017, 06:18 PM   #3
GalsofEscape's Avatar
Also, are you using the tool? Click image for larger version
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 04-22-2017, 06:21 PM   #4
No, I wasn't. Is it in the drawer with the filter?
Old 04-22-2017, 06:23 PM   #5
Mine was in the drawer under the dinette seat.
Old 04-22-2017, 06:27 PM   #6
That was where they threw everything like the toilet paper holder, the paper towel holder and other miscellaneous stuff.
Old 04-22-2017, 06:45 PM   #7
rsdata's Avatar
it does not turn easily, and needs the tool to get off and make an effective seal when putting back on...
however many, including myself have taken the filter out of the system and just hooked the inlet and outlet lines together... as these filters have been prone to failure... they break and water goes all over
then the filter is usually in a hidden place where water damage can go unseen for some time
opt for an outside filter that hooks to the water inlet like this
https://www.walmart.com/ip/Camco-Wat...-Hose/14504321
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 04-22-2017, 07:29 PM   #8
What do you do when there isn't water hook up and you have to use your tank?
Old 04-22-2017, 07:44 PM   #9
rsdata's Avatar
You probably will fill the tank with filtered water, either from a potable water source or home. You can always use the external filter on a hose to fill your tanks. Besides, most only use tank water for flushing or washing... use bottled water for drinking.
2014 Shamrock 183
Old 04-23-2017, 09:47 AM   #10
GeoArm's Avatar
j nM jn
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
roo, water, water filter
