Can’t seem to get water pressure enough to get a decent shower spray in my 2021 RPOD R192. Other pressure is ok. Water pump doesn’t seem to pump continuously as it does with sink, toilet etc. Same problem when plumbed to water supply with 50PSI regulator. It isn’t even a sprinkle. The outside spray attachment has good pressure.
Rev Joe
Have you taken off the shower head to see if 1) anything is blocking the water getting through the spray head and 2) water comes out of the hose at a good volume/pressure?
I am still trying to determine how to get the shower from a sprinkle to a shower in my 2021 RPOD R-192. There are water restrictors built into the shower head that aren't removable. However the pressure seems too low before it gets to the restrictor. Pump doesn't fully energize when water valves are opened even fully. When using city water connection 50 PSI regulator it is the same. Water restrictor can't be removed from shower head or hose. I know not to try and get info from Forest River as I can't reach anyone or get a return phone call. Being only 90 days old and not being able to use shower is quite disappointing as you can imagine. So if anyone has additional suggestions on a remedy or how to improve, please let me know.
Rev Joe
