Originally Posted by FrankH35
When I was filling the fresh water tank I did notice it was spewing out more water than usual and I'm wondering if the outside seal may have popped loose. I'm thinking I might need to reglue that seal around the opening where you put in the hose. I'll try that and see if it helps.
The fresh water tank is not under pressure. The seal is not the cause of your problem.
It could be a leak somewhere. or it could be the check valve (one-way valve) in the water pump. The water pump draw water from the fresh water tank until pressure builds up between the pump and the fixtures. That pressure seems to be leaking away, either through plumbing or backwards through the pump due to a leaky check valve.
The leaky check valve is often found when people hook up to city water. The system leaks back into the fresh water tank until it overflows. You could try hooking up to city water as a test. (In this context, city water means any water coming from a pressurized hose.)
One easy way to fix this is to simply put another check valve in the plumbing in front of the pump.
