Old 01-08-2021, 12:57 PM   #1
Sandpiper Replacement Toilet
I have a 2012 Sandpiper and it needs a new toilet. Is there a specific model I need to get or are they all essentially the same and can I just grab any RV toilet from Amazon?
Dometic 302300071 300 Series Standard Height Toilet, White
https://www.amazon.ca/dp/B007TQJTFK/...v_ov_lig_dp_it
or even better reviewed
Thetford 42169 Aqua-Magic Residence RV Toilet - High Profile, White
https://www.amazon.ca/dp/B00DPIVZGC/...v_ov_lig_dp_it
evileddie is offline   Reply With Quote
Old 01-08-2021, 05:03 PM   #2
Head Rambler
Different RV toilets have different setbacks, so if your toilet sits close to the wall you need to make sure you get one that will fit.
If you have room a Dometic 320 is a very good replacement toilet. It has an 11" backset.
Gotta go campin!
Old 01-08-2021, 05:27 PM   #3
I assume the factory installed brand is Dometic since everything else seems to be that brand (trailer is winterized in another city during the winter so I can't tell what I have)
replacement, sandpiper
