Old 06-16-2021, 03:38 PM   #1
Sanitizing fresh water tank
When sanitizing the fresh water tank with chlorine, is it ok to sanitize the water heater tank too? I have the Atwood aluminum tank heater and I'm not sure how to bypass the heater tank.
hogdooz is offline   Reply With Quote
Old 06-16-2021, 05:01 PM   #2
Always Learning
Yep, won't hurt it.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 06-16-2021, 07:57 PM   #3
Doppleganger's Avatar
Yep, won't hurt it.
We did ours, just make sure you run plenty of water thru it afterwards.
2016 Jeep Grand Cherokee Overland 5.7
2020 Coachman Apex Nano 187RB Outfitter & Off-Grid
Doppleganger is offline   Reply With Quote
Old 06-16-2021, 08:25 PM   #4
Our drain it after sanitizing.
NavyLCDR is offline   Reply With Quote
Old 06-18-2021, 06:48 AM   #5
I would bypass hot water heater.
Steve & Annette
2016 Berkshire XLT 43A
OnBarrowedTime is offline   Reply With Quote
Old 06-22-2021, 08:02 AM   #6
Flushing is your friend. Disinfecting your entire water system is key. When done, pull the plug on the water heater, and flush the heck out of it. Be sure to flush less obvious areas also such as washer hookups, outside showers, etc.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 06-22-2021, 08:26 AM   #7
Chuck_S's Avatar
The water filter cartridge in our Roo claims to remove chlorine and filter the water so I make sure it's removed before running a sanitation solution thru the system. I do the water heater as well, doesn't cost anything.
If you think this is fun imagine sanitizing the 900 gallon water trailers in the Army. Still called "water buffalos" like the old 400 gallon 2-wheel trailers.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-22-2021, 02:40 PM   #8
-- Chuck
And you just had to trust that the water came from a "clean" source. Or get used to the taste of the "purifying chemicals".
Interesting that someone found it necessary to put a fire extinguisher on a water tank.
Don't recall them on our 60's models.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
fresh water, tank, water, water tank
