Old 03-05-2017, 07:42 AM   #1
Sewer hose extension
I recently purchased a new Roo and am preparing/learning as much as I can before taking it camping. The dealer gave me a cheap sewer hose for draining. I'm going to get a new one but I've heard that people recommend having an extension too. Can I (or is it worth the cost) to convert what they gave me into an extension?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is offline   Reply With Quote
Old 03-05-2017, 07:49 AM   #2
fonzie's Avatar
I have the Rhino Flex 15 feet hose plus a 10 feet extension, used the extension a couple times, so I think it is still a good idea to have......
https://www.google.ca/search?q=rhino...PKiGjwTuv5rYAQ
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 03-05-2017, 07:57 AM   #3
Homebrew's Avatar
Get a heavy duty kit with two sections like Rhino flex. You won't regret it. Save the cheap one that came with your camper for emergencies.
You may want to order a support to keep your hose off the ground for the connections that stick up above the ground. Also a clear 45deg fitting so you can see when your tank is clean when flushing your tanks.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 03-05-2017, 09:00 AM   #4
WFD
Don't waste your time with the cheapo the dealer gave you....buy the RhinoFlex along with either the 5ft or 10ft extension and you will be much happier.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-05-2017, 09:03 AM   #5
BandJCarm's Avatar
Had bad luck with two Rhino hoses. Plus, the caps were not permanent. Went to Valterra Viper and like it better. That said, I think I could design a much better sewer hose arrangement than what is available............
My next project is to custom cut some regular house gutters and use them as support for the hoses leaving the trailer............bungee-ing them to the hose.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 03-05-2017, 09:36 AM   #6
Rhino is a very good hose "IF" before you use them you "Secure and Lock" the end caps,they are NOT properly ready to use 50% of the time! Also "Before Use" look inside and you "Will/May" see a flap/tab where they cut the hose off that MUST be trimmed or it will cause "Waste Tank Debris" to catch! Youroo!!
Old 03-05-2017, 02:44 PM   #7
Agree with others get rid of the cheap hose. Get a good one that you like. I have a Dominator 20 foot one. I like it is in two pieces and its accordion folding style. Its probably mid grade, very durable.
2016 Coachmen Freedom Express Liberty Edition 292BHDS
FRRVR is offline   Reply With Quote
