Old 06-11-2024, 05:49 AM   #1
Shower drain leak
I have a 2023 Palomino Puma 31RLQS. Found the shower drain has been leaking at the white tightening nuts by the elbow. I haven't taken it apart yet. Maybe theres no gasket?
My kitchen drain didnt have any and fixed that leak with a compression gasket.
Any clue what type of gasket I need here? Does it look like it's assembled correctly?
The space is incredibly tight to work with so I'm hoping to do this in one shot. Should I add any kind of bonding agent to the threads? T-tape maybe.
I'm sure I can fix this myself even though I'm in warranty. My TT is on a seasonal site and I have no tow vehicle. Or bite the bullet and have a tech come out. I haven't contacted FR warranty yet.
Pic attached.
IDK why the pic is posting upside down so why not F that up too.
Meh.
PUMA31RLQS is offline   Reply With Quote
Old 06-11-2024, 07:00 AM   #2
Welcome to the forum, I see it is your 1st post!
You are just going to have to get in there and see what's up.
There have been multiple reports on this forum of the shower drain leaking with everything from loose/misaligned fittings to a cracked shower pan.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 06-11-2024, 11:01 AM   #3
I would check to see if the fittings are tight.
They may have compression washers inside.
Mokurt is online now   Reply With Quote
leak, drain, show, shower
