Shower drain leak under shower pan
Water getting into underbelly... What can I expect? Will it rot? Will it get moldy? I don't have an insulated underbelly, so it's just linoleum, OSB floor, ~2" fiberglass insulation, then coroplast sheeting.
I was showering last night and when I stepped out, the rug was wet. I initially thought maybe I didn't have the curtain inside the shower. But then I saw some water coming from under the access panel below the shower pan. I opened the access panel and the damn drain union was dripping and the floor was soaked with about 1/4" of water!
I immediately hand tightened the union and grabbed my towel and sopped up as much water as I could through the small access panel and in between the drain pipe and water lines snaking around under there. I grabbed my wet vac and sucked up all I could and then used another towel to finish dry whatever I could reach (about 50% of the area is accessible due to the piping blocking most of the access).
Thankfully the weather here is fantastic - 70*F and windy - so that will help dry out the mess with windows open. I left a box fan running last night and continuing to run today while I'm at work. Since there's a big size difference between the size of the access panel and the fan, I've got the fan angled a certain way to try and get as much air into the hole as possible. Looking this morning, it all looked dry, including the 2x4's that are supporting the shower pan, but I know it's not completely dry.
Under the shower pan, there are two 3" holes in the floor - one for water piping to come up from outside and the other for electrical wiring to pass to the underbelly. These holes go straight through to the outside, save they have sprayfoam insulation on the underbelly to keep things on the outside coming into the trailer (the bad part of this is that water draining from inside will sit down in the hole with nowhere to go).
I went out to drain my gray tank, which drain is directly below the shower, and I noticed dripping coming from under the shower. The water was dripping out of the corner of my trailer's underbelly, where the coroplast meets the edge of the trailer. All this dripping after cleaning up the mess. I did run my hand along the coroplast to feel for sitting water but I didn't feel any pooling.
So, am I going to die of black mold one of these days?
2021 Shasta 18FQ
2023 Ram 1500 4X4 Lone Star Crew Cab 5.7L HEMI eTorque
Attachment 251949
