Old 05-29-2017, 08:39 PM   #1
Shower leak, 2017 Wildcat 29RLX
First trip out. When you take a shower the right side in the storage belly leaks from re back of the box that houses the water in, cable, ect.. Now would best guess be around the shower drain or what?? To get from dealer, I took pictures and will be sending them to him. Looking for a fix so the rest of the trip goes smooth Thanks, Jim
2014 Ford F-150 SuperCab 4X4
2015 ROO 21SS
Jim101 is offline   Reply With Quote
Old 05-29-2017, 08:51 PM   #2
A32Deuce's Avatar
Is there any way to look under the shower. Had a leak in mine, opened the screw hatch and found the elbow had a small crack from no support under it. Lowes to the rescue.
A32Deuce is online now   Reply With Quote
Old 05-30-2017, 12:41 AM   #3
I'll have a look , thanks, Jim
2015 ROO 21SS
Old 06-01-2017, 08:56 PM   #4
Is this at city water connection?
ryansundermeyer is offline   Reply With Quote
Old 06-02-2017, 10:25 AM   #5
No
2015 ROO 21SS
Old 06-02-2017, 11:09 AM   #6
Do you have pictures?
Old 06-02-2017, 11:54 AM   #7
Looks like we got it fixed.
Yesterday we just worked on the drain, I removed the grate and sealed around the area of the drain pipe and tub....Just tested it, no leak...I'll consider it fixed tomorrow.
2015 ROO 21SS
Old 07-05-2017, 10:30 AM   #8
My shower is leaking to put new putty around drain and new gasket in elbow stopped it for a while now leaking again fixing to take back to dealer just wondering That when in shower the floor flexes seems like it needs support there is anyone else have same problem
larry59 is offline   Reply With Quote
Old 07-05-2017, 01:02 PM   #9
A32Deuce's Avatar
Buy some stiff foam insulation and stack under shower base to firm up.
Old 07-05-2017, 01:12 PM   #10
Ok thanks I'll give it a try
Old 07-05-2017, 01:18 PM   #11
Bama PrimeTime's Avatar
When we bought our trailer in 2014, we find our leak was due to the shower drain never having been connected to the trap pipe. The alignment was perfect,but the two were not screwed together. We were three showers in before water began dripping under the trailer.
John
Ted
Bama PrimeTime is offline   Reply With Quote
Old 07-10-2017, 05:56 PM   #12
Shower leak in Freedom Express
Noticed a water drip at the outside rear of my Freedom Express where the shower is located. Pulled the access panel at the bottom of the corner shower and found water collecting in the corner below the faucet under the shower pan. Caulked the seam where the shower pan meets the side panel with no fix. Pulled the faucet unit and found a loose hose connection on the cold water side. Tightened the connection and put it all back together with a little clear caulk on the seams. Fixed Is it so difficult for factory reps to ensure all plumbing connections are tight before delivery????
2014 Ram 1500 HEMI Lone Star Edition
2018 Coachmen Freedom Express 248RBS
2017 Harley Davidson Road Glide
Roberte52 is offline   Reply With Quote
Old 07-10-2017, 06:13 PM   #13
crunchman12001's Avatar
To fix the shower pan flex, you need to access the area under the shower through the access panel.
On my old unit, I cut pieces of plywood that wood fit through the access panel. I then cut small pieces of 2 x 4 ( about 3" tall ) and wedged the 2 x 4's between the bottom of the plywood and the floor.
Firmed it right up.
2015 F-250 FX4
Old 08-25-2017, 10:52 PM   #14
alphadog99's Avatar
Too bad Forest River doesn't give a S*** about their products or customers. On our second and last FR product.
2016 Wildcat 29RLX
2011 GMC Sierra 2500HD Duramax CC
Banks tuner, airbox and filter
Rancho RS9000XL's and Firestone airbags
Pullrite Superglide 18k hitch
alphadog99 is offline   Reply With Quote
Old 08-25-2017, 11:09 PM   #15
NMWildcat's Avatar
So much anger! Good luck finding any RV manufacturer who meets your criteria for caring. They are all having record sales. Must not be too many unhappy folks.....
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
cat, leak, show, shower, wildcat
