Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 08-28-2018, 05:26 PM   #1
Showermiser warning
I took my new 2019 Rockwood Minilite 2506s TT on it’s first camping trip. I hooked the city water up, checked everything (hot and cold water on all faucets) and went to sleep. The next morning I woke up to hear water running outside. Water was running out my fresh water fill.
After hours of troubleshooting and replacing the water pump, we figured out it was this simple lever in the shower.
This “Showermiser” lever when enabled will recycle water to the fresh water holding tank, and then when the water is hot, turns color to indicate time to flip back so when dry camping you aren’t wasting water down the drain while waiting for it to heat up.
Apparently it doesn’t care if the water source is city water, it still sends the water to the fill. Maybe this is an alternative way to fill your fresh water holding tank, but beware, there is no warning if it gets bumped or moved by mistake. Your tank will fill and keep flowing.
MMRGOOD is offline   Reply With Quote
Old 08-28-2018, 05:49 PM   #2
Mine has a sticker warning about this And that also means your water was turned on all night as well.Click image for larger version
2018 Rockwood GeoPro 19FBS
2016 Chevy Silverado 1500 4x4
wevitt is offline   Reply With Quote
Old 08-28-2018, 06:27 PM   #3
tom39's Avatar
That is an interesting feature that I didn’t know existed.
Additionally, you may want to consider draining your fresh water tank prior to heading out at the end of your trip. Some model RVs are not designed to travel with the tank full of water. When I posed this to FR, I was told that the strapping holding the tank was not designed to withstand the forces exposed to them during travel and greatly increase the risk of failure. In other words, the tank drops out during travel.
2011 Rockwood 8288 SS UL
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 08-28-2018, 07:01 PM   #4
Originally Posted by wevitt View Post
Mine has a sticker warning about this And that also means your water was turned on all night as well.Attachment 184754
Thank you for sending that picture. We picked up our camper 5 weeks after the posted manufacturing date. The sticker is there, but it is completely faded. It must have been in direct sun or chemically washed away. I am glad they have posted that sticker, but now I’m concerned how mine faded so quickly. There is no text at all left on the sticker.
Old 08-28-2018, 07:01 PM   #5
I did just that. Thanks!
Old 08-29-2018, 10:51 AM   #6
What is proper position of lever to not send water to Fresh Tank?
jeffmich3 is offline   Reply With Quote
Old 08-29-2018, 11:13 AM   #7
BriaBeck's Avatar
Did you leave your shower turned on all night?
Brian & Becky
2018 Avenger ATI 27RBS
Champion 3500
Weber Q2000, Blackstone 22", and a whole herd of flamingoes
BriaBeck is offline   Reply With Quote
Old 08-29-2018, 11:18 AM   #8
If you turn the water on and move the lever you will see one allows water out of the shower and one does not. I only turn the hot water and move the lever down. No water will come out of the shower, When the pipe turns white i move the lever up and water now comes out of the shower.
Old 08-29-2018, 06:58 PM   #9
No. The shower was not running.
Old 08-29-2018, 06:59 PM   #10
The proper position is with the lever facing the wall. As shown in my original post.
Old 08-29-2018, 07:01 PM   #11
Updated photo
Old 08-29-2018, 07:05 PM   #12
I am not to sure they are all the same. Mine is in the correct position in my picture which looks different than the other picture. I think it would be correct to say the position that allows water to come out of the shower head is the correct position.
Old 08-29-2018, 08:47 PM   #13
Agreed!
show, shower
