Shurflow water pump not working
Before I run out and buy a replacement pump I thought I'd check with you guys in case I've overlooked something.
I was trying to sanitize my water lines and in doing so ran out of bleach/ water solution I was drawing out of container. I dove inside the motorhome and shut the pump off .After refilling the container the pump would not reset . I checked the fuse and it appears to be ok . In addition there's also voltage across the supply leads to the pump.
All this is leading me to conclude that the pump is pooched but I could be mistaken Any thoughts
